Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
Remove the top of the vacuum bin by pulling it straight up.
Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
Remove the casing that surrounds the fan by pulling it straight up.
Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
Remove the casing from the fan and battery component by pulling it straight up.
Remove the small black button from the top of the battery.
