Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide outlines how to replace the entire fan unit rather than fixing the entire unit itself, because doing so would require advanced techniques such as soldering. This replacement is needed when dirt clogs the fan due to the close proximity between the fan and the vacuum bin.
O que você precisa
Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
