Ir para o conteúdo principal
iRobot Roomba 560 Fan Replacement
O que você precisa
  1. iRobot Roomba 560 Fan Replacement, Fan: passo 1, imagem 1 %32
    • Press the black circular button on the back end of the Roomba and pull the bin out towards you to remove the vacuum bin.
  2. iRobot Roomba 560 Fan Replacement: passo 2, imagem 1 %32 iRobot Roomba 560 Fan Replacement: passo 2, imagem 2 %32
    • Lay the vacuum bin down and remove the six 15 mm screws around the outside of the vacuum bin using the Phillips JIS #1 driver.
    • Remove the top of the vacuum bin by pulling it straight up.
    • The bin is composed of two parts (the clear top casing and the red bottom filter). To avoid a mess, be careful to not let these two pieces detach, unless over a trash bin.
  3. iRobot Roomba 560 Fan Replacement: passo 3, imagem 1 %32 iRobot Roomba 560 Fan Replacement: passo 3, imagem 2 %32 iRobot Roomba 560 Fan Replacement: passo 3, imagem 3 %32
    • Remove the three 10 mm screws that surround the fan using the Phillips JIS #1 driver.
    • Remove the casing that surrounds the fan by pulling it straight up.
    • The casing is composed of 2 parts (the large top casing, and a small air filter). If these parts detach, they are very easy to put back together. Do not lose the air filter.
  4. iRobot Roomba 560 Fan Replacement: passo 4, imagem 1 %32 iRobot Roomba 560 Fan Replacement: passo 4, imagem 2 %32 iRobot Roomba 560 Fan Replacement: passo 4, imagem 3 %32
    • Turn over the remainder of the fan casing and remove the single 15mm screw, using the Phillips JIS #1 screwdriver.
    • Remove the casing from the fan and battery component by pulling it straight up.
  5. iRobot Roomba 560 Fan Replacement: passo 5, imagem 1 %32
    • Remove the small black button from the top of the battery.
    • Save the spring and the button cover. The remainder of the fan assembly (yellow motor and the black housing) will need to be replaced as a unit.
Conclusão
TJ Tamura
Membro desde: 10/01/15
277 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-22, Maness Fall 2015 Membro de Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 26
Duração total: 4,266
