Ir para o conteúdo principal
iRobot Roomba 551 Battery Replacement
O que você precisa
  1. iRobot Roomba 551  Battery Replacement, Side Brush: passo 1, imagem 1 %32
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - Responder
  2. iRobot Roomba 551  Battery Replacement: passo 2, imagem 1 %32
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: passo 3, imagem 1 %32
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: passo 4, imagem 1 %32
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: passo 5, imagem 1 %32 iRobot Roomba 551  Battery Replacement: passo 5, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: passo 6, imagem 1 %32
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: passo 7, imagem 1 %32 iRobot Roomba 551  Battery Replacement, Battery: passo 7, imagem 2 %32
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 13-14, Regan Winter 2014 Membro de Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
Membros da 4
Autoria de 19 guias
Um comentário
Thank you Deborah!
James - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 121
Duração total: 9,678
