Ir para o conteúdo principal
iRobot Roomba 4160 Spinning Edge Brush Replacement
O que você precisa
  1. iRobot Roomba 4160 Spinning Edge Brush Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Spinning Edge Brush Replacement: passo 2, imagem 1 %32 iRobot Roomba 4160 Spinning Edge Brush Replacement: passo 2, imagem 2 %32
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
  3. iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: passo 3, imagem 1 %32 iRobot Roomba 4160 Spinning Edge Brush Replacement, Spinning Edge Brush: passo 3, imagem 2 %32
    • Locate the spinning brush that is directly to the left of the rectangular pocket for the battery pack.
    • Unscrew the 7.2mm Phillips #1 screw from the spinning brush.
  4. iRobot Roomba 4160 Spinning Edge Brush Replacement: passo 4, imagem 1 %32
    • Gently pull the spinning brush upwards to remove it.
Conclusão
Garrett Rasmussen
Membro desde: 04/07/14
225 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-4, Forte Spring 2014 Membro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 378
