Ir para o conteúdo principal
iRobot Roomba 4160 Brush Replacement
  1. iRobot Roomba 4160 Brush Replacement, Brush Guard: passo 1, imagem 1 %32
    • Make sure the Roomba is turned off to prevent injury.
    • Turn the Roomba upside down so that the underside is exposed. The wheels and brushes should be visible.
    • Identify the brush guard, which is the black rectangular frame that the metal rods are attached to.
  2. iRobot Roomba 4160 Brush Replacement: passo 2, imagem 1 %32
    • Locate the 2 small rectangular yellow tabs on either side of the brush guard, directly adjacent to the blue flap.
    • Place index fingers on both tabs, and apply slight pressure in the direction of the yellow battery pack.
    • While you are applying pressure, the guard should hinge up in the direction of the yellow battery pack.
  3. iRobot Roomba 4160 Brush Replacement: passo 3, imagem 1 %32 iRobot Roomba 4160 Brush Replacement: passo 3, imagem 2 %32
    • After the guard hinges up, lift the guard up and away from the Roomba.
  4. iRobot Roomba 4160 Brush Replacement, Brush: passo 4, imagem 1 %32
    • Remove the wire brush by grabbing it by the yellow plastic part of the brush.
    • Pull the brush upwards until it comes out.
  5. iRobot Roomba 4160 Brush Replacement: passo 5, imagem 1 %32 iRobot Roomba 4160 Brush Replacement: passo 5, imagem 2 %32
    • Remove the rubber spinning brush by grabbing it by the rubber part on both ends.
    • Pull the brush upwards until it dislodges.
Conclusão
noah falck
Membro desde: 04/07/14
104 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 6-4, Forte Spring 2014 Membro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 322
