Ir para o conteúdo principal
iRobot Roomba 4160 Battery Replacement
  1. iRobot Roomba 4160 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the Roomba is turned off to avoid an electric shock.
    • Turn the Roomba upside down, and place it so that the underside is exposed. The wheels and brushes should be visible.
    • Do not attempt to open up the yellow battery pack. You may get shocked or burned by the battery acid.
  2. iRobot Roomba 4160 Battery Replacement: passo 2, imagem 1 %32 iRobot Roomba 4160 Battery Replacement: passo 2, imagem 2 %32
    • Identify the yellow plastic rectangular battery, directly to the right of the spinning brush.
    • Place your index fingers on the small rectangular plastic tabs on both sides of the battery. Push the tabs in until the battery comes loose.
    • Pull battery out using your fingers.
Conclusão
To re-install battery, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Garrett Rasmussen
Membro desde: 04/07/14
225 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 6-4, Forte Spring 2014 Membro de Cal Poly, Team 6-4, Forte Spring 2014
CPSU-FORTE-S14S6G4
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 940
