Ir para o conteúdo principal
iRobot Roomba 4100 Flexible Rubber Brush Replacement
  1. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Brush Guard: passo 1, imagem 1 %32
    • Lay the Roomba upside down on a flat surface with the blue strip away from you.
  2. iRobot Roomba 4100 Flexible Rubber Brush Replacement: passo 2, imagem 1 %32 iRobot Roomba 4100 Flexible Rubber Brush Replacement: passo 2, imagem 2 %32
    • Use your index fingers to pull the yellow tabs towards you.
    • While still pulling the yellow tabs with your index fingers, tilt up the brush guard.
    • For reassembly, make sure to push in the brush guard until it clicks into place.
  3. iRobot Roomba 4100 Flexible Rubber Brush Replacement: passo 3, imagem 1 %32
    • Pull back the brush guard to unhook it from the latches.
    • Remove the brush guard by lifting it up and out of the Roomba.
    • This picture has a change in orientation to illustrate the latches. Continue disassembling the Roomba with the blue strip away from you.
  4. iRobot Roomba 4100 Flexible Rubber Brush Replacement, Flexible Rubber Brush: passo 4, imagem 1 %32
    • Set the brush guard aside.
    • The flexible rubber brush is the smooth, all-rubber brush that is closest to the yellow battery.
  5. iRobot Roomba 4100 Flexible Rubber Brush Replacement: passo 5, imagem 1 %32 iRobot Roomba 4100 Flexible Rubber Brush Replacement: passo 5, imagem 2 %32
    • Remove the flexible rubber brush by grabbing it and pulling it up and out of the Roomba.
    • For reassembly, orient the Roomba with the battery closest to you:
    • First, insert the black end of the flexible rubber brush into the black square opening on the right side.
    • Second, lay the flexible rubber brush back into place.
Conclusão
Samantha Barrett
Membro desde: 01/13/14
501 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-5, Forte Winter 2014 Membro de Cal Poly, Team 17-5, Forte Winter 2014
CPSU-FORTE-W14S17G5
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 917
