Ir para o conteúdo principal
iRobot Roomba 4100 Battery Pack Replacement
O que você precisa
  1. iRobot Roomba 4100 Battery Pack Replacement, Battery Pack: passo 1, imagem 1 %32
    • Turn the Roomba upside down to be able to see the yellow battery pack.
  2. iRobot Roomba 4100 Battery Pack Replacement: passo 2, imagem 1 %32 iRobot Roomba 4100 Battery Pack Replacement: passo 2, imagem 2 %32
    • Remove the battery by placing your fingers into the two holes and firmly press your fingers against both sides of the battery.
    • Lift the battery directly up and out of the device.
  3. iRobot Roomba 4100 Battery Pack Replacement: passo 3, imagem 1 %32
    • Line up the replacement battery’s larger tab side with the larger tab hole and the smaller tab side with the smaller tab hole.
    • Insert the replacement battery into the empty space and firmly press down onto the battery until two audible clicks are heard.
Conclusão
Your iRobot Roomba 4100 is now ready for use.
Scott Leonard
Membro desde: 10/05/10
445 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-6, Maness Fall 2010 Membro de Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
Membros da 2
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 8,368
