Introdução
If your iRobot Mint is having trouble moving, this guide will show you how to take it apart and get it going again.
O que você precisa
Eight Phillips screws are located underneath the stickers.
Carefully cut around the 8 screw holes using an X-acto knife or razor blade to reveal the screws.
Remove the screws with a #2 Phillips screwdriver.
With the device upside down, pull up to separate the bottom from the top cover.
Locate the three arrows on each wheel.
Insert metal spudger at arrow locations to pop off the wheel covers.
Remove four #2 Phillips and lift off retainer.
Pull out all weights and set aside
Uma outra pessoa concluiu este guia.
2 comentários
Nice! Very helpful.
Popping the wheel covers as shown breaks the small hooks that hold the wheel cover on. You need to rotate the cover clock wise to release them. There probably is a special tool that uses the small impressions in the cover.
