Ir para o conteúdo principal
iRobot Looj 120 Controller Buttons Replacement
O que você precisa
  1. iRobot Looj 120 Controller Buttons Replacement, Removing Screws: passo 1, imagem 1 %32
    • Remove the four exterior screws located under controller and on the handle.
    • Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
  2. iRobot Looj 120 Controller Buttons Replacement, Locate Circuitry: passo 2, imagem 1 %32
    • Disconnect circuit board from power leads, and install new circuit board.
  3. iRobot Looj 120 Controller Buttons Replacement, Remove Exterior Screws: passo 3, imagem 1 %32
    • Remove the four exterior screws to gain access to inner components. These screws are located on the bottom of the controller and on the handle.
    • Remove the five interior screws to access the buttons.
  4. iRobot Looj 120 Controller Buttons Replacement, Accessing the Buttons: passo 4, imagem 1 %32
    • Remove top plate carefully so that none of the electrical components are damaged.
    • Remove the broken button and insert the new button into the mounting hole.
Conclusão
Uma outra pessoa concluiu este guia.
Lucas Otto
Membro desde: 11/12/14
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-5, Duarte Fall 2014 Membro de UMass Dartmouth, Team 2-5, Duarte Fall 2014
UMASSD-DUARTE-F14S2G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 227
