Ir para o conteúdo principal
iRobot Braava Jet 240 Wheel Replacement
O que você precisa
  1. iRobot Braava Jet 240 Wheel Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device off.
  2. iRobot Braava Jet 240 Wheel Replacement: passo 2, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement: passo 2, imagem 2 %32
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Wheel Replacement, Mop Pad: passo 3, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement, Mop Pad: passo 3, imagem 2 %32
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Wheel Replacement: passo 4, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement: passo 4, imagem 2 %32 iRobot Braava Jet 240 Wheel Replacement: passo 4, imagem 3 %32
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Wheel Replacement: passo 5, imagem 1 %32
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Wheel Replacement, Wheel: passo 6, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement, Wheel: passo 6, imagem 2 %32
    • Using your thumbs, first push back the motor assembly, then push up.
  7. iRobot Braava Jet 240 Wheel Replacement: passo 7, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement: passo 7, imagem 2 %32
    • Remove the 11.55 mm screws in the middle of both wheels using the Phillips #1 screwdriver.
  8. iRobot Braava Jet 240 Wheel Replacement: passo 8, imagem 1 %32 iRobot Braava Jet 240 Wheel Replacement: passo 8, imagem 2 %32 iRobot Braava Jet 240 Wheel Replacement: passo 8, imagem 3 %32
    • Pull the wheel off from the axel, pulling from the top end first so it can slide out at an angle.
    • It will be easier to remove the wheels if the motor assembly is tilted so that the wheel that you are removing is elevated.
Conclusão
8 outras pessoas executaram este guia.
Claire Franz
Membro desde: 02/10/20
2.784 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S22-G2, Regan Winter 2020 Membro de Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
Membros da 5
Autoria de 12 guias
6 comentários
Thank you so much!
Michaela - Responder
Where can I get the replacement wheels?
John
john - Responder
iRobot does not sell replacement parts for the 240, other than things like batteries. I look for dead As-Is units on eBay and buy them to scavenge parts. (And it really irks me that iRobot doesn't sell the parts!)
William Fickas -
Thanks, William Fickas! I wish I knew this when I bought my 240. Selling their product but not keeping long term customers happy seems to be this company's mantra.
ejhcornelisse - Responder
Followed the guide and a spring fell out!? It has 5 turns and about 1" long with a 3/16" loop on one end? I'm thinking that I lifted the wheel assembly up just a bit too high. Any idea where that spring came from? Maybe somewhere in the middle of the assemble? Other than that the guide is perfect! Thank you and keep up the good work!
Bob Read - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 94
Duração total: 8,807
