Ir para o conteúdo principal
iRobot Braava Jet 240 Tank Replacement
O que você precisa
  1. iRobot Braava Jet 240 Tank Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device off.
  2. iRobot Braava Jet 240 Tank Replacement: passo 2, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 2, imagem 2 %32
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Tank Replacement, Mop Pad: passo 3, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement, Mop Pad: passo 3, imagem 2 %32
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Tank Replacement: passo 4, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 4, imagem 2 %32 iRobot Braava Jet 240 Tank Replacement: passo 4, imagem 3 %32
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Tank Replacement: passo 5, imagem 1 %32
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Tank Replacement, Front Shell: passo 6, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement, Front Shell: passo 6, imagem 2 %32
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
    These screws have a non-threaded top. So they’ll move after unscrewing but not come out.
    At this stage it’s best to lift them and continue to unscrew until they’re removed as this makes removing the cover easier.
    Same for the other two 15mm screws.
    The Virtual Traveller - Responder
  7. iRobot Braava Jet 240 Tank Replacement: passo 7, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 7, imagem 2 %32
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Tank Replacement: passo 8, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 8, imagem 2 %32 iRobot Braava Jet 240 Tank Replacement: passo 8, imagem 3 %32
    • Carefully pull back on the front shell to remove it from the robot.
  9. iRobot Braava Jet 240 Tank Replacement, Back Shell: passo 9, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement, Back Shell: passo 9, imagem 2 %32
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. iRobot Braava Jet 240 Tank Replacement: passo 10, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 10, imagem 2 %32
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. iRobot Braava Jet 240 Tank Replacement: passo 11, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 11, imagem 2 %32 iRobot Braava Jet 240 Tank Replacement: passo 11, imagem 3 %32
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
  12. iRobot Braava Jet 240 Tank Replacement, Tank: passo 12, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement, Tank: passo 12, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the two 9.7 mm screws on the tank.
  13. iRobot Braava Jet 240 Tank Replacement: passo 13, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 13, imagem 2 %32 iRobot Braava Jet 240 Tank Replacement: passo 13, imagem 3 %32
    • Pull up on the L - shaped plastic piece and remove it from the tank assembly.
  14. iRobot Braava Jet 240 Tank Replacement: passo 14, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 14, imagem 2 %32
    • Lift the tank up and away from the device.
    • Don't pull the tank too hard because it is still attached to the water tube at the back.
  15. iRobot Braava Jet 240 Tank Replacement: passo 15, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 15, imagem 2 %32 iRobot Braava Jet 240 Tank Replacement: passo 15, imagem 3 %32
    • First pull up, then pull down on the spring to detach it from the hooks.
  16. iRobot Braava Jet 240 Tank Replacement, Remove the motherboard case: passo 16, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement, Remove the motherboard case: passo 16, imagem 2 %32
    • Lift up on the motherboard case to remove it from the device. This will expose the water tube that is attached to the tank.
  17. iRobot Braava Jet 240 Tank Replacement: passo 17, imagem 1 %32 iRobot Braava Jet 240 Tank Replacement: passo 17, imagem 2 %32
    • Pull the tubing off of the tank connector.
Conclusão
3 outras pessoas executaram este guia.
Claire Franz
Membro desde: 02/10/20
2.760 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S22-G2, Regan Winter 2020 Membro de Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
Membros da 5
Autoria de 12 guias
5 comentários
Good guide. I would suggest doing steps 13-16 before step 12 and a small hook (bent wire, staple or the like) makes reattaching the spring (step 15) a lot easier. Otherwise, perfect.
Gareth Thomas - Responder
Thanks Claire for this. I have an issue and maybe you can help with it. https://imgur.com/a/Nw3nxrM
Thanks!
Diego Cacivio - Responder
I agree with moving steps 13-16 before step 12. Two reasons. First, it may be easier to remove the water tube from the tank while the tank is fastened in place. Second, removal of the motherboard case is an important building block step that provides access to free-floating platform, motors, tubing, and magnetic pads. I am roughing out a guide for removing the motherboard case built on this guide that you might be able to use. Feel free to edit it if you'd like.
Elven Decker - Responder
it would be nice if someone has a way to add an external water bottle to give more water to the unit. Thanks
Sing LoveTo - Responder
Okay tank is out….question is how do you CLEAN it ?
Daniel Rafanowicz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 70
Duração total: 3,664
