Introduction
If the tank in your iRobot Braava Jet 240 needs to be replaced, follow this guide.
After water is poured into the robot and passes through the filter, it is held in the tank. The tank is connected to the tubing and pump. This allows the robot to eject water from the nozzle onto the cleaning surface.
The tank might need to be removed, cleaned, and reinstalled if the robot is spraying dirty water. If the tank itself is damaged, it should be completely replaced.
Parts
No parts specified.
  1. Turn the device off.
    • Turn the device off.
  2. Use your fingers to gently pop out the battery. Use your fingers to gently pop out the battery.
    • Use your fingers to gently pop out the battery.
  3. Lift up the handle to reveal the eject button. Lift up the handle to reveal the eject button.
    • Lift up the handle to reveal the eject button.
  4. Use your finger to push the eject button forward. Use your finger to push the eject button forward. Use your finger to push the eject button forward.
    • Use your finger to push the eject button forward.
  5. Tilt the robot on its side and let the mop pad slide out.
    • Tilt the robot on its side and let the mop pad slide out.
  6. Remove the two 22.0  mm screws on the bottom-front of the robot using a Phillips #1 screwdriver. Remove the two 22.0  mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot. Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. Carefully pull back on the front shell to remove it from the robot. Carefully pull back on the front shell to remove it from the robot. Carefully pull back on the front shell to remove it from the robot.
    • Carefully pull back on the front shell to remove it from the robot.
  9. Insert a Phillips #1 screwdriver through the screw holes. Unscrew the two 9.7 mm screws.
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver. If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. Pull up on the back shell to remove it from the robot. For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal. For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
  12. Use a Phillips #1 screwdriver to remove the two 9.7 mm screws on the tank. Use a Phillips #1 screwdriver to remove the two 9.7 mm screws on the tank.
    • Use a Phillips #1 screwdriver to remove the two 9.7 mm screws on the tank.
  13. Pull up on the L - shaped plastic piece and remove it from the tank assembly. Pull up on the L - shaped plastic piece and remove it from the tank assembly. Pull up on the L - shaped plastic piece and remove it from the tank assembly.
    • Pull up on the L - shaped plastic piece and remove it from the tank assembly.
  14. Lift the tank up and away from the device. Don't pull the tank too hard because it is still attached to the water tube at the back.
    • Lift the tank up and away from the device.
    • Don't pull the tank too hard because it is still attached to the water tube at the back.
  15. First pull up, then pull down on the spring to detach it from the hooks. First pull up, then pull down on the spring to detach it from the hooks. First pull up, then pull down on the spring to detach it from the hooks.
    • First pull up, then pull down on the spring to detach it from the hooks.
  16. Lift up on the motherboard case to remove it from the device. This will expose the water tube that is attached to the tank. Lift up on the motherboard case to remove it from the device. This will expose the water tube that is attached to the tank.
    • Lift up on the motherboard case to remove it from the device. This will expose the water tube that is attached to the tank.
  17. Pull the tubing off of the tank connector. Pull the tubing off of the tank connector.
    • Pull the tubing off of the tank connector.
2 other people completed this guide.
Claire Franz
1.458 Reputation
7 Guides authored
Cal Poly, Team S22-G2, Regan Winter 2020 Member of Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
5 Members
8 Guides authored
3 Comments
Good guide. I would suggest doing steps 13-16 before step 12 and a small hook (bent wire, staple or the like) makes reattaching the spring (step 15) a lot easier. Otherwise, perfect.
Gareth Thomas - Responder
Thanks Claire for this. I have an issue and maybe you can help with it. https://imgur.com/a/Nw3nxrM
Thanks!
Diego Cacivio - Responder
I agree with moving steps 13-16 before step 12. Two reasons. First, it may be easier to remove the water tube from the tank while the tank is fastened in place. Second, removal of the motherboard case is an important building block step that provides access to free-floating platform, motors, tubing, and magnetic pads. I am roughing out a guide for removing the motherboard case built on this guide that you might be able to use. Feel free to edit it if you'd like.
Elven Decker - Responder
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 85
All Time: 1,982
