Ir para o conteúdo principal
iRobot Braava Jet 240 Back Shell Replacement
O que você precisa
  1. iRobot Braava Jet 240 Back Shell Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device off.
  2. iRobot Braava Jet 240 Back Shell Replacement: passo 2, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 2, imagem 2 %32
    • Use your fingers to gently pop out the battery.
  3. iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: passo 3, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement, Mop Pad: passo 3, imagem 2 %32
    • Lift up the handle to reveal the eject button.
  4. iRobot Braava Jet 240 Back Shell Replacement: passo 4, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 4, imagem 2 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 4, imagem 3 %32
    • Use your finger to push the eject button forward.
  5. iRobot Braava Jet 240 Back Shell Replacement: passo 5, imagem 1 %32
    • Tilt the robot on its side and let the mop pad slide out.
  6. iRobot Braava Jet 240 Back Shell Replacement, Front Shell: passo 6, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement, Front Shell: passo 6, imagem 2 %32
    • Remove the two 22.0 mm screws on the bottom-front of the robot using a Phillips #1 screwdriver.
  7. iRobot Braava Jet 240 Back Shell Replacement: passo 7, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 7, imagem 2 %32
    • Use a Phillips #1 screwdriver and an iFixit opening tool to remove the two 15.0 mm screws on the front sides of the robot.
  8. iRobot Braava Jet 240 Back Shell Replacement: passo 8, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 8, imagem 2 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 8, imagem 3 %32
    • Carefully pull back on the front shell to remove it from the robot.
  9. iRobot Braava Jet 240 Back Shell Replacement, Back Shell: passo 9, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement, Back Shell: passo 9, imagem 2 %32
    • Insert a Phillips #1 screwdriver through the screw holes.
    • Unscrew the two 9.7 mm screws.
  10. iRobot Braava Jet 240 Back Shell Replacement: passo 10, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 10, imagem 2 %32
    • Unscrew the four 9.7 mm screws using a long neck #1 Phillips screwdriver.
    • If the screws are unscrewed but do not come out easily, turn the robot upside down and gently shake it.
  11. iRobot Braava Jet 240 Back Shell Replacement: passo 11, imagem 1 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 11, imagem 2 %32 iRobot Braava Jet 240 Back Shell Replacement: passo 11, imagem 3 %32
    • Pull up on the back shell to remove it from the robot.
    • For reassembly, pop the mop pad release trigger back into place if it fell out during back shell removal.
Conclusão
Claire Franz
Membro desde: 02/10/20
2.784 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team S22-G2, Regan Winter 2020 Membro de Cal Poly, Team S22-G2, Regan Winter 2020
CPSU-REGAN-W20S22G2
Membros da 5
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Duração total: 1,194
