Introdução
Without properly functioning wheels, the Braava will have a difficult time navigating. This will lead to inefficient sweeping or mopping. This guide will show how to replace the Braava's wheels.
O que você precisa
With the battery removed, rotate your device so the front of it is facing you.
Remove the four 10mm Phillips #2 screws that attach the shell.
To remove the wheel covers, hold the wheel in place with one hand while turning the cover clock-wise with the other.
13 outras pessoas executaram este guia.
Um comentário
O roteiro descritivo para a troca das rodas do Braava foi muito útil. Obrigada!
