Ir para o conteúdo principal
iRULU AX106 Disassembly
O que você precisa
  1. iRULU AX106 Disassembly, iRULU AX106 Disassembly: passo 1, imagem 1 %32
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Disassembly: passo 2, imagem 1 %32 iRULU AX106 Disassembly: passo 2, imagem 2 %32
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Disassembly: passo 3, imagem 1 %32 iRULU AX106 Disassembly: passo 3, imagem 2 %32 iRULU AX106 Disassembly: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
Conclusão
3 outras pessoas executaram este guia.
Andrew Mele
Membro desde: 03/24/15
146 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 Membro de UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G7
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,654
