Ir para o conteúdo principal
iPod Touch 7th Generation Rear-Facing Camera Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, imagem 1 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, imagem 2 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, imagem 3 %32
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 2, imagem 1 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 2, imagem 2 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 2, imagem 3 %32
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 3, imagem 1 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 3, imagem 2 %32
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 4, imagem 1 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 4, imagem 2 %32 iPod Touch 7th Generation Rear-Facing Camera Replacement: passo 4, imagem 3 %32
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Conclusão
Tarun Thiruma
Membro desde: 11/20/19
35.268 Reputação
Autoria de 134 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 7
