Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the flat end of a spudger between the rear-facing camera and its frame.
Gently twist the spudger to free the camera.
Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
Run the spudger along the full length of the tape to disconnect it from the rear case.
Peel and remove the foam tape from the rear case of the iPod.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
