Ir para o conteúdo principal
iPod Touch 5th Generation Battery Replacement
O que você precisa
    • Follow this video guide from start to finish and enjoy!
Conclusão
Did you follow all the steps? Yes! Then enjoy!
29 outras pessoas executaram este guia.
Fix It Planet
Membro desde: 05/29/15
1.561 Reputação
Autoria de 3 guias
22 comentários
The solder in the video looks like a clear liquid, I’m I missing something. I’m used to solder that looks like wire? Is there something new that is easier to use?
Thanks for putting this up, I’m trying to decide if I can do the soldering and I just want to make sure I know what I’m getting myself into.
Joshua Edwards - Responder
Sorry for the confusion. That clear liquid is actually flux. The solder has been put on the iron tip prior to soldering the pads. Not much solder is needed but the flux is necessary to help the flow and bonding of the solder.
Fix It Planet - Responder
What kind of wick do you use?
Nick DeRissio - Responder
Goot wick. Model: CP - 2015 Width: 2 mm
Fix It Planet -
Could I use an IOpener tool to open the ipod?
Best Songs - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 78
Últimos 30 dias: 387
Duração total: 38,973
