Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Restore life to your iPod Touch 2nd Generation by replacing the logic board.
O que você precisa
The picture at left (front panel already removed) shows the locations of the metal clips (shown in red) that snap on to the plastic frame. In the next few steps, try to pry the front panel up from the gaps between these clips.
Insert a small iPod opening tool with the edge angled up toward the underside of the display between the white plastic backlight and the metal shield beneath it.
Pry up along the lower edge of the display enough to grab it with your fingers.
Use the flat end of a spudger to pry the battery off the adhesive securing it to the metal display tray.
Remove the metal display tray and set it aside.
Lay the battery flat in the rear panel.
52 outras pessoas executaram este guia.
