Ir para o conteúdo principal
iPod Shuffle 4th Generation Rear Panel Replacement
O que você precisa
  1. iPod Shuffle 4th Generation Rear Panel Replacement, Rear Panel: passo 1, imagem 1 %32
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Rear Panel Replacement: passo 2, imagem 1 %32 iPod Shuffle 4th Generation Rear Panel Replacement: passo 2, imagem 2 %32
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. iPod Shuffle 4th Generation Rear Panel Replacement: passo 3, imagem 1 %32
    • Remove the rear panel from the Shuffle.
Conclusão
5 outras pessoas executaram este guia.
2 comentários
what glue to fix it?
pedro_bizarro - Responder
I recommend 2mm TESA tape
Ben Capehart -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 37
Duração total: 9,512
