Ir para o conteúdo principal
iPod Shuffle 3rd Generation Logic Board Replacement
O que você precisa
  1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: passo 1, imagem 1 %32
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Logic Board Replacement: passo 2, imagem 1 %32 iPod Shuffle 3rd Generation Logic Board Replacement: passo 2, imagem 2 %32
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Logic Board Replacement: passo 3, imagem 1 %32
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Logic Board Replacement: passo 4, imagem 1 %32
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: passo 5, imagem 1 %32
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Logic Board Replacement: passo 7, imagem 1 %32
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
Conclusão
Matthew Newsom
Membro desde: 01/05/10
41.929 Reputação
Autoria de 67 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 6,676
