Ir para o conteúdo principal
iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement
O que você precisa
  1. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Rear Case: passo 1, imagem 1 %32
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 2, imagem 1 %32 iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 2, imagem 2 %32
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 3, imagem 1 %32
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 4, imagem 1 %32
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Logic Board: passo 5, imagem 1 %32
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 6, imagem 1 %32
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 7, imagem 1 %32
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Headphone Jack & Shuffle Switch: passo 8, imagem 1 %32
    • Pry the headphone jack from the front case with an iPod opening tool.
    • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
  9. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 9, imagem 1 %32
    • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  10. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 10, imagem 1 %32
    • Remove the headphone jack and shuffle switch from the front case.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Newsom
Membro desde: 01/05/10
39.685 Reputação
Autoria de 67 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 12,032
