Introdução
Replace a malfunctioning battery to juice up an old iPod Shuffle.
O que você precisa
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Start working from the right side of the battery ribbon cable. Heat the right solder pad while gently prying up from under the ribbon cable to free it from the board.
6 outras pessoas executaram este guia.
7 comentários
IS THIS DONE ANYWHERE IN cHENNAI-mADRAS sOUTH iNDIA PL INFORM.
Is this done anywhere in Chennai- Madras South India?
Im going to try and replace the battery with a 3rd party battery and was wondering if you knew which side was the positive and negative
Hi where have u got the battery from
Rishii k -
Anyone having any luck finding replacement batteries?
I order some from here:
https://www.alibaba.com/product-detail/O...
Worked great, my shuffle has 12 hours of battery life again <3
