Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
Use a plastic opening tool to pull the rear plastic cover away from the device until there is enough room to insert a spudger.
Insert a spudger under the cover, then pry it up and away from the device.
Remove the rear plastic cover from the iPod.
Remove the single 1.4 mm Phillips #000 screw from the black plastic spacer.
Use a plastic opening tool to remove the black plastic spacer from the Nano.
Remove the two 2 mm Phillips #000 screws from the bottom of the case.
Insert a plastic opening tool into the seam between the white plastic front panel and the rear case.
Slide the opening tool along the edge of the front panel to free it from clips and adhesive.
Use a spudger to press the midframe screw tab up and out of the rear case.
Use a metal spudger to carefully pry near the Lightning connector and under all parts of the front panel assembly: the front glass/digitizer, the LCD display and the metal midframe.
Continue prying along the edges under the front panel assembly, releasing the clips and adhesive along the sides of the device.
Pull the front panel assembly slightly down and partially out of the device.
Use a spudger to release the digitizer cable and display data cable connectors.
Gently unfold the two halves of the device to access the internal components.
Pull up on the battery pull tab to free the battery from its adhesive.
Completely separate the front panel assembly from the rest of the device.
