O que você precisa
Insert a spudger under the metal midframe and display on the left side of the home button.
Rotate the spudger around the home button and across the front panel, releasing the adhesive holding the display in place.
Uma outra pessoa concluiu este guia.
Is not easier to remove the LCD first from the metal midframe?
I think this will prevent any damage to the LCD while trying to release adhesive around the home button and and the metal midframe
rallenfl - Responder
I am trying to put it my LCD back on my dgitizer and there is a wire on the digitizer and i cant figure out witch way to bend it.
Scott P. - Responder
esta es la manera dificil de hacerlo. Para que quitar el marco metalico del touch?
Andreu Bonafonte - Responder
