Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace your iPod Nano's outer casing.
O que você precisa
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Remove the following five screws:
One 1.7 mm Phillips screw
Four 3.9 mm Phillips screws.
Remove the following three screws:
One black 1.8 mm Phillips screw
Two 1.7 mm Phillips screws
13 outras pessoas executaram este guia.
