Ir para o conteúdo principal
iPod Mini Top Bezel Replacement
O que você precisa
  1. iPod Mini Top Bezel Replacement, Top Bezel: passo 1, imagem 1 %32
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Mini Top Bezel Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Jimmy
    $7.95
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
  3. iPod Mini Top Bezel Replacement: passo 3, imagem 1 %32
    • Lift the top bezel off of the iPod.
Conclusão
13 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 635 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 16,063
