Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The shiny rear half or your iPod case.
O que você precisa
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
Remove the 3 silver Philips screws securing the headphone jack to the rear panel.
10 outras pessoas executaram este guia.
