Ir para o conteúdo principal
iPod 3rd Generation Touch Wheel Cable Replacement
O que você precisa
  1. iPod 3rd Generation Touch Wheel Cable Replacement, Case: passo 1, imagem 1 %32
    • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
    Pergunte ao FixBot
  2. iPod 3rd Generation Touch Wheel Cable Replacement: passo 2, imagem 1 %32 iPod 3rd Generation Touch Wheel Cable Replacement: passo 2, imagem 2 %32 iPod 3rd Generation Touch Wheel Cable Replacement: passo 2, imagem 3 %32
    • Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
    • You may need to rock the pick back and forth to slide it in farther.
    • Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
    • Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
    • After all five tabs along the right side are free, the case should open easily.
    Pergunte ao FixBot
  3. iPod 3rd Generation Touch Wheel Cable Replacement: passo 3, imagem 1 %32
    • The iPod case is now open, but don't separate the two halves just yet. There is still an orange ribbon cable connecting the headphone jack to the logic board.
    • Open the case like a book with the dock connector at the top, and lay the rear panel next to the front half of the iPod.
    Pergunte ao FixBot
  4. iPod 3rd Generation Touch Wheel Cable Replacement: passo 4, imagem 1 %32 iPod 3rd Generation Touch Wheel Cable Replacement: passo 4, imagem 2 %32
    • Use a plastic tool or your fingernails to carefully disconnect the orange headphone jack cable. Be sure to pull straight up on the connector, not the cable itself.
    • The headphone jack connector is unusually tall. When prying, be careful to not separate the lower, plastic part of the connector from the ribbon cable. Pry between the connector and the socket, not between the two halves of the connector.
    Pergunte ao FixBot
  5. iPod 3rd Generation Touch Wheel Cable Replacement, Logic Board: passo 5, imagem 1 %32
    • Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
    Pergunte ao FixBot
  6. iPod 3rd Generation Touch Wheel Cable Replacement: passo 6, imagem 1 %32
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    Pergunte ao FixBot
  7. iPod 3rd Generation Touch Wheel Cable Replacement: passo 7, imagem 1 %32
    • Use a spudger to carefully disconnect the orange touch wheel cable from the logic board.
    Pergunte ao FixBot
  8. iPod 3rd Generation Touch Wheel Cable Replacement: passo 8, imagem 1 %32
    • Remove the 6 black T6 Torx screws securing the logic board to the front panel.
    Pergunte ao FixBot
  9. iPod 3rd Generation Touch Wheel Cable Replacement: passo 9, imagem 1 %32
    • Lift the logic board out of the iPod.
    • When reassembling your iPod, be sure that the plastic hold switch mechanism is synced with the hold switch on the logic board. The switch on the board is a small black nub that sits in a slot on the hold switch mechanism.
    Pergunte ao FixBot
  10. iPod 3rd Generation Touch Wheel Cable Replacement, Touch Wheel Cable: passo 10, imagem 1 %32
    • Use a spudger to carefully disconnect the orange touch wheel cable from the front panel.
    • Lift the touch wheel cable out of the iPod.
    Pergunte ao FixBot
Conclusão
4 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
1Comentário do guia
peças de reposição onde encontrar?
viana.deividi10 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 94
Ao todo: 9,119
