Ir para o conteúdo principal
iPod 1st Generation Display Replacement
O que você precisa
  1. iPod 1st Generation Display Replacement, Rear Panel: passo 1, imagem 1 %32
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Boy, are these cases hard to open! I got nowhere with the spudger, but I did have success using duct tape. This is worth trying as it reduces the likelihood of scratching the case. Make a tab by sticking duct tape to the metal case starting on the side down by the scrolll wheel and ending up where the metal case ends on the firewire side. Fold excess duct tape back on itself so that it is 2x thick anywhere it isn’t stuck to the iPod. This is where you are going to grab it. Rub the duct tape with a spudger or a fingernail where it touches the iPod to make it stick better. Make a similar tab on the other side. Now grab the iPod in your right hand with your thumb at the 1/8” audio connector, squeeze gently, and pull on one of the duct tape tabs. (I stared with the one of the lock button side, but I don’t think it matters.) It is smooth sailing once the case starts to open up. Clean off any duct tape residue with alcohol wipes before re-assembly.
    R Calhoun - Responder
    Well, maybe for you because you have baby hands and, it Took me less Then a minute to do it
    Matthew Cabanas -
  2. iPod 1st Generation Display Replacement: passo 2, imagem 1 %32
    • Opening the iPod can be challenging; don't get discouraged if it takes you a few tries to get the iPod to open.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. iPod 1st Generation Display Replacement: passo 3, imagem 1 %32
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. iPod 1st Generation Display Replacement: passo 4, imagem 1 %32
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. iPod 1st Generation Display Replacement: passo 5, imagem 1 %32
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    • Lift the rear panel away from the iPod.
  6. iPod 1st Generation Display Replacement, Hard Drive: passo 6, imagem 1 %32
    • Lift the battery up from the adhesive holding it to the iPod.
    • Lay the battery next to the iPod (it is still connected to the logic board).
  7. iPod 1st Generation Display Replacement: passo 7, imagem 1 %32
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
  8. iPod 1st Generation Display Replacement, Display: passo 8, imagem 1 %32
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
  9. iPod 1st Generation Display Replacement: passo 9, imagem 1 %32
    • Peel up the gray rubber bumper near the hard drive ribbon to reveal the T6 Torx screw beneath.
    • Remove the newly revealed T6 Torx screw.
  10. iPod 1st Generation Display Replacement: passo 10, imagem 1 %32
    • Remove the 3 remaining T6 Torx screws from the logic board.
  11. iPod 1st Generation Display Replacement: passo 11, imagem 1 %32
    • Slide the logic board away from the port end of the casing and lift it out of the iPod.
  12. iPod 1st Generation Display Replacement: passo 12, imagem 1 %32
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
  13. iPod 1st Generation Display Replacement: passo 13, imagem 1 %32
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
  14. iPod 1st Generation Display Replacement: passo 14, imagem 1 %32
    • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
Conclusão
Uma outra pessoa concluiu este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
2 comentários
How do you connect new display screen?
tiarana_senele - Responder
iPod 初代のディスプレイは第2世代のディスプレイと全く同じものですか?
ryu mym - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 27
Duração total: 9,955
