Ferramenta utilizada nesse passo:Pro Tech Toolkit$74.95
次日早晨,苹果带给我们我们一直在期待的:新的iPhone 5!
非常感谢澳大利亚MacFixit让我们在墨尔本使用他们的挖掘机进行拆卸。 他们有Mac和iPhone升级/配件,并且销售iFixit工具包。
这就是iPhone5
4"1136 × 640 像素 (326 ppi) 视网膜显示
苹果 A6 系统芯片 (SoC)
8 万像素摄像头 iSight 摄像头
8 针闪电连接器
4g LTE 连接
iOS 6
can you test to see how easy the black comes off from the case.. Big question in forums called "Scuff Gate"
I replaced the battery. But only last week I put it on charge. With genuine apple charger. But in the morning the battery had swollen up. Popping the screen.. I still have my i fixit tool kit so i checked the battery and it was soft like jelly. I checked about replacement and I was directed to the Australian site. Where the price is double the price i paid for the same battery i had sent from I fixit in CA. Also the postage in Australia. Was over "$15 dollars. Looks like the Australian store is robbing us locals and the last one from the US WAS shipped by air … Would management care to explain . The reasons.. ?????
Ferramenta utilizada nesse passo:P2 Pentalobe Screwdriver iPhone$5.99
麻烦的五角螺丝! 好的是我们的五角螺丝刀仍然有用。
苹果在iPhone 4和4S上使用了两年来一直使用的相同的pentalobe螺丝刀,这是非常方便的。 螺丝轴与我们的iPhone 4 / 4S拆解套装]中的螺丝略有不同,所以我们制作了一款新的iPhone 5拆卸套装]!
一体机后壳让人联想到iPhone 3GS,同时仍然保留了iPhone 4的正方形(虽然现在已经倒角)。
这是什么? 吸盘? 自3GS以来,我们不需要一个吸盘来进入iPhone!
因为iPhone 5是从前到后打开的,更换破解的屏幕将比以前更容易。 谢谢苹果!
与iPhone 4S进行比较,隔离显示器组件需要38个步骤,而这个iPhone可能是我们在一段时间内看到的最可修复的iPhone。
屏幕排线用几个简单的十字螺丝固定在主板上。
用撬棒挑开屏幕排线,就可以取出屏幕。
这是 iPhone 3GS 屏幕总成的链接。
手贱党和屏幕修理者欢呼吧!
I have noticed that the 3 screws that remove the plate that connects the digitizer and the glass , 2 of which are magnetic and one 1 non magnetic, does anyone know the reason for this?
I read somewhere here that it's to prevent GPS interference, as the GPS module is located right next to it.
Uhh just a quick one! I was not paying attention as to which hole the non magnetised screw came out of. Can anyone tell me which hole it came out of please?
用电池拆卸标签拉出电池。不要试图撬软包电池,因为这可能导致过热!
iPhone 5 苹果采用了不同的电池化学物质,电压更高,容量略大于iPhone 4S。让我们看看电池的规格是怎样的。
iPhone 5电池: 3.8V - 5.45Wh-1440mAh。通话时间:3G通话时间最长可达8小时。待机时间:225小时。
iPhone 4S电池:3.7V - 5.3Wh - 1432mAh。通话时间:3G通话时间最长可达8小时。待机时间:200小时。
三星Galaxy S III电池:3.8V - 7.98Wh - 2100mAh。通话时间:3G通话11小时40分钟。待机时间:790小时。
在电池背面,我们看到“MFR索尼”和“新加坡制造的电池”。谷歌一下,很有可能是索尼制造的。
I was looking at the conversion for 5.45 Wh to mAh and noticed that the value is actually closer to 1434 mAh when using the following math: (5.45Wh * 1000)/3.8V ≈ 1432 mAh. Am I missing something?
Hi, what is the physical size of the iphone 5 battery (LxWxH)? I can find this info for older iphones but can't seem to find for this one. thx!
iPhone 5内部有各种各样的金属对金属触点。
弹簧触点易于维修,但要求在重新组装前仔细注意清洗所有部件。手指油脂会妨碍金属接触,导致部件故障。
该触点将前置摄像头周围的金属框架连接到后置摄像头周围的框架。也许这个框架是某种天线?只有时间能证明一切。
说到天线,撬棒可以很容易将天线连接器的一端从电池附近的主板上撬下来。
在iPhone 4S中,这个天线位置是预留给蜂窝天线的。在我们继续拆解之前,我们无法确定这个天线的用途。
What is the little metal box on the top right called
主板的底部充满了组件。
Skyworks 77352-15 GSM/GPRS/EDGE功放模块
SWUA 147228是一个射频天线开关模块
用于UMTS波段的Triquint 666083-1229 WCDMA / HSUPA功率放大器/双工模块
Avago AFEM-7813双频LTE B1/B3 PA+FBAR双工模块
Skyworks 77491-158 CDMA功率放大模块
Avago A5613 ACPM-5613 LTE波段13功放
How do you remove the plates without messing them up? Looks like they are soldered on the motherboard.
Through either desoldering, cutting, or straightup ripping them off the board -- whichever method yields the least-destructive, but also speedy result.
We love it when a motherboard has a frame that's soldered, and little covers that go on top of the frame. We can remove those without any damage whatsoever.
更多的芯片在下面的主板
高通PM8018射频电源管理IC
海力士 H2JTDG2MBR 128gb (16gb) NAND闪存
苹果 338S1131对话电源管理IC*
苹果338S1117卷云逻辑D类放大器。里面的模具是一个卷云逻辑设备(第二张图片),但它看起来不像音频编解码器。
意法半导体L3G4200D (AGD5/2235/G8SBI)低功耗三轴陀螺仪,与iPhone 4S、iPad 2等主流智能手机相同。
Murata 339S0171(基于Broadcom BCM4334) Wi-Fi模块
Apple 338S1117 chip can't be Elpida memory MCP for LTE, because the LTE chipset in on the other edge of the board.
In addition to Alexander Zuev comment : is the GPS chipset BCM47511, or a new combo one?
The response is: No! Qualcomm MDM9615M is a Gobi™ modem which includes a built-in GPS chip GLONASS enable. No specs are available for this chip (sensitivity, number of channels, SBAS)
Francis -
有人要 苹果 338S1077音频芯片的特写吗?
音频芯片做什么?简而言之,它是单一的芯片,既可以进行数字信号转化为模拟信号,也可模拟信号转化为数字信号,从而正确的编码和解码音频输入和输出信号。
That is Apple 338S1077 Speaker ic,Apple 338S1117 Cirrus Logic is the Audio Codec!
Dear people if you disassemble an device never use tools to pry up any connectors flexes, use your finger nails to exclude damage of SMD parts,some people guided to use such tools when take off GPS flex cable on iPhone 5 they damage IMEI ic which stay in corner of simholder after that ic damages you can trash your phone,and there are many other faults caused by such tools so be careful!
支持4G的iPhone ?这比你想象的更有可能。
我们现在可以确认Qualcomm MDM9615M是支持这一新功能的4G LTE调制解调器。
高通MDM9615M基带采用28nm工艺,支持 LTE (FDD和TDD)、HSPA+、EV-DO Rev B、TD-SCDMA。
MDM9615支持多光谱、多模式LTE。它负责在LTE上传输同步语音和数据传输(前提是运营商具备同步语音和数据传输的基础设施)。
我们也发现高通RTR8600多波段/多模射频收发器。RTR8600与MDM9615配对以支持各种波段,包括5个UMTS波段、5个LTE波段和4个EDGE波段。
在完全分析主板之后,我们把注意力转回到后盖上。
即使是大量的胶粘剂也经不起我们强大的撬棒!
闪电连接器组件,其中包括耳机插孔,扬声器,和底部的麦克风,浮现出来。
看来Wi-Fi天线也被嵌入到组件中。iPhone 5现在支持2.4 GHz和5 GHz。
天线的尺寸是全波长的一部分,所以2.4 GHz四分之一波的1.23"与5 GHz半波的1.18"英寸非常接近,一个天线可以同时为两个频率服务。
So you still haven't updated this about the Wi-Fi antenna? There's already another guide telling where the Wi-Fi antenna is. The Murata Wi-Fi module is far from the speaker so this coaxial connector should belong to mobile phone functions. iPhone 5 Wi-Fi Antenna Replacement
闪电连接器看起来可能会吞噬30针底座连接器。
在这里,我们可以清楚地看到新的闪电连接器的八个引线
虽然还没有任何关于闪电连接器的官方消息,但我们可以肯定地说其中两个将用于电源和地。至于其他6个,好吧,还任人猜测。
更新:我们现在知道闪电连接器的引出线是什么。
苹果公司声称闪电连接器是全数字化的。然而,他们还声称iPhone 5支持模拟音频输出和VGA视频,这表明电缆内部可能正在进行某种数模转换。
As for conversion D/A and A/D in a Lightening cable,(to support analog A/V output) it is also possible that the port is mode sensing. I have seen a number of devices now that mode sense on USB ports to provide analog A/V out, as well as USB/OTG functions depending on which cable is plugged in.
振子上的压力触点意味着更换它不需要焊接或撬开排线。
不像iPhone 4S使用的是线性振动的马达,苹果已经回归到带有平衡力的旋转马达。
You could barely feel the linear oscillator. I'm glad they went back to the rotational motor. At least now you'll be able to feel it vibrating in your pocket.
I think this patent (below) is the reason Apple no longer uses a linear oscillator. Oh and who owns the patent I hear you ask? A: Samsung.
苹果最新版的经典home键采用了集成的金属支架,我们希望这将大大加强这个经常使用按键的耐用性。
许多iPhone 4和4S用户都经历过home键故障的痛苦,但他们都没有足够的勇气尝试修复。这种新设计不仅可以延长使用寿命,还可以大大减少更换home键的麻烦。
并排比较iPhone 4和iPhone 5的屏幕。iPhone 4s有一个集成的home键。
Hi. On photo 28, those pair of contacts on printed pcb from the home button are going to be connected to a pair of contacts-springs that are near the lightning connector. Where do these contacts-springs are connected to ? I have a case of faulty home button that after replacing the home-button assembly, it is still failing. What could be the cause ? I’ve read that the home button when it fails, 9 out of 10 cases is due to the button itself. My case is 10% remaining. Any idea? Thanks.
根据用户的要求,我们研究了对“磨损门”的担忧,即担心黑色涂层太容易磨损。
我们发现这面很硬,但是倒角的边缘很容易磨损,使得侧面有一道闪亮的条纹。
这个故事的寓意是:小心,否则就会有麻烦。或者像风一样自由,只是不在乎。
我们找到他们了!正如苹果公司承诺的那样,更多的麦克风安装在设备顶部。
首先,我们找到了前置麦克风,可能是用于FaceTime和降噪麦克风功能。
后面呢?它开始看起来像一个三重麦克风!后置麦克风与后置摄像头配合拍摄视频,也可用于消除通话时的背景噪声。
My amend suggesting the purpose of the rear mic was deleted by Brett, but the rear mic is *definitely* used for recording sound when filming video. To verify, blow on the mic during recording, then temporarily cover it with your finger for comparison. Covering this mic with your finger totally mutes the wind noise.
iPhone 5的可修性:7 / 10(10是最容易修复的)
我们很高兴,玻璃盖板+显示屏的组合iPhone 5是第一个。iPhone的大部分维修都是因为前玻璃盖板碎了。
电池很容易取出。
iPhone 5的外部仍然使用了五角螺丝,这使得它更难打开。
玻璃盖板,触摸板,和液晶显示器都是一个组件,因此增加了维修成本。
许多较小的部件焊接在一条带状电缆上,增加了仅修复一个部件的成本。
I'm very happy to see Apple including a SIM card tool again, but how do you get the nanoSIM to stay in the full-size holder?
Um agradecimento especial a esses tradutores:
97%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
51 comentários
Keep it coming guys...great.
Great job .. this is what exactly i was waiting for
AMAZING! Thanks for getting this out there! I've suspected that this phone was going to be easier to replace the screen ever since the leaked parts started pouring in.
Thank God it's not like the iPod Touch 4th Gen display.
When are you going to do a tear-down on the 5th Gen iPod touch?
cool and looks so nice too
Excellent description and beautiful photos as always. You folks do an excellent job.... with one minor request for more... The details of the antennas are not clear. In particular, where exactly are the 3G/4G antennas? Is the metallic ring around the perimeter of the phone part of an antennae again as in "antennagate?" (I don't think so, but would like confirmation). Also, are the diversity antennas used over all the bands?
quick one: which chip is used for GPS and does it dual GPS/GLONASS as it was in 4S?
What kind of plastic does the iPhone 5 casing use? (The part that connected to the aluminum stripe across the back). I dropped my phone down some stairs and the plastic part cracked.
Sadly, those parts in the rear case are glass, so there isn't much you can do to fix them short of replacement. Check out this Answers post about taking those parts out.
Looks like Chipworks has their teardown up: http://goo.gl/H65BgS
Hi I have water damage on my iPhone 5 and I would like to fix it.
I've read your water damage guide and I didn't understand if you can/have to clean all the parts where there's some corrosion visible or just the logic board and LCD? Will it help if I clean everything with a cloth moistened in isopropyl alcohol?
Thanks, and I commented here because the last article about water damage is very old and outdated it's on the iPhone 3G so I posted on this active guide.
Thanks for the post. There are so many little pieces inside that little phone! I loved how one of the pieces says "Apple Kor." Thanks for the teardown.
Rachel Zane | http://www.accuratewesternscale.com/prod...
wow i have just finished replacing my iphone 5 screen scary at first but not so complicated. make sure you dont drop any screw, the suction pad didnt work for me, i had to pry the bottom screen, do it gently so you dont leave any marks on the phone. once out every thing is straight forward, carefull with the home button, on mine it was stuck on original phone with adhesive. so taking out the flat cable was a delicate process. other wise phone is brand new and works well and look brand new. thanks Ifixit.com
Where to find the quartz oscillator?
I'm very happy to resove my problem [url=http://www.bigophonepascher.com//]Galaxy S4 pas cher[/url]
What kind of plastic does the iPhone 5 casing use? (The part that connected to the aluminum stripe across the back). I dropped my phone down some stairs and the plastic part cracked. Can i use this parts <a href="http://www.makibadi.com/acheter-telephon... rel="nofollow">Accessoire iPhone 6/</a>
This part will also fix a broken home button if the little copper contacts have been ripped off by a co worker that messed with your broken down phone after you told him not to
I have a problem in My iPhone 5! It do not recognize da the original Lightning cable charge or usb on the computer.. I already try to change the conector... Is saem thing in the main board! Sorry about My english! Please help!
The iPhone 5 was the most beautiful iPhone, especially the silver one. It was the the lightest until now and quite fast. I wished I hadn't sold mine. It was the last iPhone Steve Jobs commissioned. It is just beautiful, elegant and light. Very fast on the iOS 10 with long battery life. I like the headphone jack.
informative post!!! thanxx for sharing .do give a post on iphone 7
it is really helpful for me since i started my repairing please keep going on and thanks a lot for helping individual repairer to run their shops.
thanks again ifixit you are doing great job for no cost. ummmaaah
My iphone 5 have a problem when it is turned on it works properly but when its battery drain to zero and phone turned off then it don't picking up charging.Help me.
Excellent guide. Please tell me if I don't have several tools, can I take it apart completely? I can't do step 29. My friend from <a href="https://papercheap.co.uk">papercheap</a> did it easy.
Very useful information about 45 and 3G networks We look forward to articles about what is 5g networks. 5G networks The latest network technology and the latest research, 5G should provide much faster connections than current networks where, with average download speeds of about 1 Gbps Allow a speed of about 10 GB.
Let’s Grow Together is your Health and Cares website. We provide you with the latest Tips and tricks of health and cares and videos straight from the Cares industry.
read full article on https://healthpartners01.blogspot.com/
Very nice blog and the information shared by you is very useful to the users like me thanks for sharing it and keep up with the good work.
<a href="http://cracedkey.com/"> cracedkey </a>
This is a great article. Detailed information has been studied before on https://foxmoney.com.ua/kredit-bez-paspo...
<a href="https://tecvase.com/ymail-sign-up-create... data-type="URL" data-id="https://tecvase.com/ymail-sign-up-create...>A Ymail account</a> offers you the opportunity to access other Yahoo products. But to sign up for Ymail, you need to have some information with you. This information is what Yahoo uses to keep your account safe and secured.
Dear All Visitors '''softwarebig.com''' is the Best Place to download the PC software, s Free of cost & With Serial key, Keygen, Crack & Full version you are also downloading the Android Games & Latest Android APPS. We are updating our site daily with the latest version. We are giving all software With Direct Download Links.
'''Grammarly Crack 2021''' is really Lucky for you personally our team lately had use of each of your beloved Grammarly Premium Accounts Cracks. We’re very happy to tell each one of you a major number of completely free grammar premium balances. No downloads samples or suggestions are available, and before discussing, we make certain that every account will do the job.
To sign in your Linksys device, type the Linksys default IP address 192.168.1.1 into the browser.We are providing best solution for your all linksys router and extender. for more information .<a href="https://linksysvelopsetup.com/">Visit on</a>
Thanks for share this blog.........i am not a regular internet reader but now am reading daily read your blog..please also <a href="https://www.httpmyrouterlocal.net">Visit on</a>
This i Phone is very good for IPTV channel streaming iptv m3u
A very good post calcul mensualité crédit for sharing !
Really enjoyed Reading this! Helped med out big Time.. good work
ROM download reference and mobile and computer training
'''Techno Related''' now imagine reassembling it a few hundred times and that's your average day at foxconn....oh and you're 12 years old...
Techno Related - Responder
