Ir para o conteúdo principal
iPhone XS Rear Camera Lens Cover Replacment
O que você precisa
  1. iPhone XS Rear Camera Lens Cover Replacment, Rear Camera Lens Cover: passo 1, imagem 1 %32
    • First, remove the shards of glass from the broken camera lens.
    Took me almost an hour to gently break glass and clean area.
    Do recommend heating the glass for easier removal.
    All in all, 75 minutes for my first time. And replacement glass is a little smaller than original (bought somewhere online).
    Adab Abu - Responder
    Where did u get the replacement part from?
    Nathanael H. W. -
  2. iPhone XS Rear Camera Lens Cover Replacment: passo 2, imagem 1 %32 iPhone XS Rear Camera Lens Cover Replacment: passo 2, imagem 2 %32
    • Once the glass shards from the camera lens have been removed, thoroughly clean the camera bezel (the raised metal part around the camera).
    only my bottom lens is cracked, how do i get a nice crack on the top lens to break the rest out
    None Of Your Business - Responder
    Help! I had a small crack. In trying to remove the glass I damaged the lens underneath and caused damage to the actual camera.
    The removal of the glass is very difficult. Can anyone provide any information on how to do it well? I have replaced iphone screens and batteries etc and this is by far the most difficult fix I’ve tried on iPhones.
    Aris Vrakas - Responder
    what was your solution? how would you do it better? heating?
    Adab Abu -
  3. iPhone XS Rear Camera Lens Cover Replacment: passo 3, imagem 1 %32 iPhone XS Rear Camera Lens Cover Replacment: passo 3, imagem 2 %32
    • Stick some double sided tape or two dots of glue on the new iPhone X rear camera cover.
    • Use tweezers to position the glass lens in its housing.
    Any suggestion about what type of glue to use? …I can’t imagine that double-sided tape is a great option…?
    Bradley Kirschner - Responder
    I'd say like T7000 or T8000 glue
    Nathanael H. W. -
  4. iPhone XS Rear Camera Lens Cover Replacment: passo 4, imagem 1 %32
    • Lightly press down on the lens for a few seconds to stick it down correctly.
    • You can test your rear camera to make sure your photos and videos have the right definition.
Conclusão
Congratulations ! You have repaired your iPhone XS, the lens is replaced, clean it with a microfiber cloth. You can now take photos and film normally.
5 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
cPix
Membro desde: 06/14/16
4.136 Reputação
Autoria de 8 guias
Um comentário
Can someone tell me where I should look for a replacement?
Nathanael H. W. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 32
Últimos 30 dias: 126
Duração total: 4,996
