Ir para o conteúdo principal
Introdução
Use this guide to remove or replace the two screws securing the iPhone XS display panel. These are the only screws on the exterior of the iPhone. They use a five-point design that is unique to Apple, requiring a specialty P2 pentalobe driver for removal.
Peças
Nenhum componente especificado.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusão
9 outras pessoas concluíram este guia.
Jeff Suovanen
Membro desde: 06/08/2013
362.440 Reputação
258 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
140 Membros
17.053 Guias de autoria
2 comentários
So you have not explained wether or not the iphone XS and the iphone X have identical pentalobe screws, what a guide it is, well infact i found out the hard way they are identical and replaceable with iphone x housing pentalobe screws, thanks.
Jonez K - Responder
On the screws what is the black stuff at the end of the screws? Because it came off my screws now I’m concerned that I have compromised the waterproof ness of my phone
Casey Hunter - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 45
Últimos 30 dias: 220
Duração total: 6,277
