Introdução
The iPhone fell and crashed? I'll show you how to replace a broken rear glass on an iPhone XR.
O que você precisa
Vídeo de Apresentação
Power off your iPhone before beginning disassembly.
Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull the blue handle towards the hinge to disengage opening mode.
Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
Push down on the cups to apply suction to the desired area.
Push the blue handle away from the hinge to engage opening mode.
Turn the handle clockwise until you see the cups start to stretch.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
Skip the next two steps.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Insert an opening pick into the gap.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
Open the iPhone by swinging the display up from the left side, like the back cover of a book.
Lean the display against something to keep it propped up while you're working on the phone.
Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
Remove the bracket.
Use the point of a spudger to pry the battery connector straight up out of its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Remove the two 1.2 mm Y000 screws securing the display connector bracket.
Remove the bracket.
Use the tip of a spudger to pry up and disconnect the digitizer cable.
Use the tip of a spudger to disconnect the display cable connector.
Remove the five screws securing the logic board connector bracket to the rear case:
One 1.3 mm Phillips #000 screw
One 1.5 mm Phillips #000 screw
Three 1.2 mm Y000 screws
Remove the bracket.
Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
Remove the seven screws securing the bracket below the Taptic engine and speaker:
Three Phillips 1.4 mm screws
Two Phillips 1.7 mm screws
One Phillips 1.9 mm screw
One Phillips 1.6 mm screw
Remove the five screws securing the lower speaker:
One 2.8 mm standoff screw
One 2.3 mm standoff screw
One 2.3 mm Phillips screw
One 1.8 mm Phillips screw
One 1.6 mm Phillips screw
Each piece of adhesive has a black pull-tab at the end, which is lightly adhered to the side edge of the battery.
Slowly pull one battery adhesive tab away from the battery, towards the bottom of the iPhone.
Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at as low an angle as possible, without snagging it on any of the iPhone's other components.
If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. This can take some time since the adhesive is slow to deform, but with patience it will come free. Do not deform or damage the battery.
Remove the 2 screws securing the camera plate
One 2.4 mm standoff screw
Remove the camera plate
With an opening tool, disconnect the camera connector
Use an opening tool or a fingernail to remove 9 connectors from the logic board.
Remove the following screws:
2.9mm standoff screw
1.5mm Phillips #000
1.6mm Phillips #000
Remove the grounding bracket
Remove the SIM reader
Remove the 5 screws securing the logic board to the case
2.9mm Standoff screw
2.8mm Standoff screw
1.8mm Phillips #000
Remove the logic board.
40 outras pessoas concluíram este guia.
4 comentários
Muy buena explicacion, me salio perfecto, hasta la taza de café me tome mientras se secaba jaja. Saludos
Excellent instruction step by step guide. Great video. This is very complete and very easy guide with superb narrative style . Thank you Mr Arty. This 40 step format , illustration and photo quality, and description narrative is gold standard practice . Thank you !
