Ir para o conteúdo principal
iPhone XR Logic Board Replacement
O que você precisa
  1. iPhone XR Logic Board Replacement, Remove the pentalobe screws: passo 1, imagem 1 %32 iPhone XR Logic Board Replacement, Remove the pentalobe screws: passo 1, imagem 2 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
    One of my gaskets was as shown in your second photo, the other had been worked into the threads (as if smeared) probably from the factory and was completely unusable.
    In place of replacements (unsure of where to purchase) I just used a clear silicone caulking on both screws upon reassembly to offer at least some water seal. I wish these gaskets were included with the gasket waterproofing sealant kit!
    Erica - Responder
    Is there any place to buy these screw gaskets? I haven’t seen it mentioned anywhere but one of mine was pretty much chewed up. Silicone should work but I’d prefer the oem solution.
    Chilinh Nguyen - Responder
    I found a place on Amazon that sells them. It's cheapest to get a full set of screws than to get just these. $5-$6 USD.
    J Olin -
    If I transfer the data from the old to the new battery with an icopy, don't I get an error message?
    David Julian Krause - Responder
    how am i supposed to know if the battery is below 25% if the screen won't turn on?
    Beth Jackson - Responder
  2. iPhone XR Logic Board Replacement, Tape over any cracks: passo 2, imagem 1 %32 iPhone XR Logic Board Replacement, Tape over any cracks: passo 2, imagem 2 %32 iPhone XR Logic Board Replacement, Tape over any cracks: passo 2, imagem 3 %32
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
    How to detect my Iphone what screen it is, OLED or LCD?
    sabrihakulii - Responder
    It’s OLED. You can find the specs here, https://support.apple.com/en-us/HT201296
    When you find your phone, at the bottom of the description click on, See the tech specs…
    mcr4u2 -
    The included suction cups were stiff and worthless. They would not lift the screen. Also, I tried every type of tape on the screen to help the suction cups stick without success. Heavy duty suction cups were for my bathroom also failed. However, I had an old GoPro mount with some preapplied double sided 3M VSB tape and stuck that on the screen near the bottom. Magic! This method had the added bonus of being able to use a GoPro attachment as a handle to lift the screen, and propped up the screen like a kickstand in step 12.
    Tawan Khamapirad - Responder
    Very cool! Thanks
    Antonio -
    My screen was pretty stuck… would not budge. Heated, super glued the suction cup, tried gorilla tape. Ended up doing the GoPro mount with 3M VSB tape method mentioned. Worked great. That 3M tape is the bomb.
    Rich Wachtel - Responder
    The included suction cup took a few tries but ended up working for me.
    charlotte - Responder
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003 thick goes right in. Work your way up until you can get the pick or supplied pry tool in.
    William Olstad - Responder
    where can I buy 3M VSB plis!!
    gerardo artigas cuellar - Responder
    3M VHB tape is at auto stores and other big box stores, or online.
    nicO -
    I used the tweezers that came with the replacement screen and jammed one of them into the glass and that eventually worked. Heating with a blow dryer is also important. The suction cup was helpful in loosening the adhesive for sure, but just not enough to get the display to come out.
    J Olin - Responder
  3. iPhone XR Logic Board Replacement, Tape over any cracks: passo 3, imagem 1 %32 iPhone XR Logic Board Replacement, Tape over any cracks: passo 3, imagem 2 %32 iPhone XR Logic Board Replacement, Tape over any cracks: passo 3, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    This looks like a repeat of Step 3.
    GenjideGaulle - Responder
  4. iPhone XR Logic Board Replacement, Anti-Clamp instructions: passo 4, imagem 1 %32 iPhone XR Logic Board Replacement, Anti-Clamp instructions: passo 4, imagem 2 %32 iPhone XR Logic Board Replacement, Anti-Clamp instructions: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Clamp
    $24.95
    Comprar
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone XR Logic Board Replacement: passo 5, imagem 1 %32 iPhone XR Logic Board Replacement: passo 5, imagem 2 %32 iPhone XR Logic Board Replacement: passo 5, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone XR Logic Board Replacement: passo 6, imagem 1 %32 iPhone XR Logic Board Replacement: passo 6, imagem 2 %32 iPhone XR Logic Board Replacement: passo 6, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Please UPDATE THIS STEP to say 'insert the opening pick underneath the PLASTIC FRAME OF THE SCREEN' and not the screen. Way too many people are taking this as the way to do it then posting their screen looks different when it's open when they've actually removed the screen leaving the frame in place. It's not rocket science.
    [deleted] - Responder
    Thanks for the suggestion! We updated this step to clarify that.
    Arthur Shi -
  7. iPhone XR Logic Board Replacement, Heat up the screen: passo 7, imagem 1 %32
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    An alternative to the Iopener or heat gun is to heat water to EXACTLY 80 degrees F (cooking thermometer is great for this) and pour into a reinforced ziplock type bag. Leave the bag on the screen, but be sure that none of the hot water rests on the zipper portion, as the water is hot enough to soften that seal and leak out on to your device! This meat had is my personal favorite as the heat is distributed very equally and precisely as compared to a heat gun, but is more accessible than the Iopener.
    Colin Wylie - Responder
    When using an iOpener, rest the glossy (transparent) side on the phone so it contacts the phone and conducts heat easily
    Afiq - Responder
  8. iPhone XR Logic Board Replacement: passo 8, imagem 1 %32 iPhone XR Logic Board Replacement: passo 8, imagem 2 %32
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone XR Logic Board Replacement, Lift the display slightly: passo 9, imagem 1 %32 iPhone XR Logic Board Replacement, Lift the display slightly: passo 9, imagem 2 %32 iPhone XR Logic Board Replacement, Lift the display slightly: passo 9, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone XR Logic Board Replacement, Separate the screen adhesive: passo 10, imagem 1 %32 iPhone XR Logic Board Replacement, Separate the screen adhesive: passo 10, imagem 2 %32 iPhone XR Logic Board Replacement, Separate the screen adhesive: passo 10, imagem 3 %32
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    I think it's important to note that depending on how a screen was damaged, make sure to insert the pic under the black bezel directly under the actual screen. This bezel is a frame around the digitizer. I unknowingly inserted the pic between the bezel and the screen, and separated them both. I did this all the way around the phone. So I basically had to struggle to keep together two different sections of the display assembly because of this mishap, until I removed all the ribbon connectors. It made things much more difficult.
    Dave - Responder
    An edit to my above comment: by digitzer, I mean the LCD shield. My apologies.
    Dave - Responder
  11. iPhone XR Logic Board Replacement, Screen information: passo 11, imagem 1 %32
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick at the marked spots, as you may damage the cables.
  12. iPhone XR Logic Board Replacement: passo 12, imagem 1 %32 iPhone XR Logic Board Replacement: passo 12, imagem 2 %32 iPhone XR Logic Board Replacement: passo 12, imagem 3 %32
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    My replacement screen for the XR has a black rim but it looks pink. Is that normal?
    Irwin Cantor - Responder
    You can use some Isopropyl alcohol in a syringe with a thin needle to soften even more the adhesive around the screen. But be careful so as not to overdo it. Just a few drops. It will become more easier to remove the screen.
    Dan Brock - Responder
    Step 11 says not to insert your pick around the right side to avoid damaging cables, then Step 12 says to insert it on the right side. Help, I'm confused!
    ingwis - Responder
    Hi there!
    Thank you for the feedback! The wording in step 11 was definitely ambiguous, so we have changed it! You only need to avoid the marked spots rather than the right edge.
    Alex Diaz-Kokaisl -
  13. iPhone XR Logic Board Replacement: passo 13, imagem 1 %32 iPhone XR Logic Board Replacement: passo 13, imagem 2 %32 iPhone XR Logic Board Replacement: passo 13, imagem 3 %32
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  14. iPhone XR Logic Board Replacement: passo 14, imagem 1 %32
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone XR Logic Board Replacement, Open the iPhone: passo 15, imagem 1 %32 iPhone XR Logic Board Replacement, Open the iPhone: passo 15, imagem 2 %32 iPhone XR Logic Board Replacement, Open the iPhone: passo 15, imagem 3 %32
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
    sure looks like the "hinge" is on the right hand side to me.. not left...!
    Doug Trout - Responder
    If you leave the suction cup attached to the screen during the “hinging” process, it makes for a very handy holder for the screen until it’s completely detached.
    Richard Deubler - Responder
    What about the sticky black adhesive clinging to the inside of the case?
    Ronald - Responder
  16. iPhone XR Logic Board Replacement, Unscrew the battery connector cover: passo 16, imagem 1 %32 iPhone XR Logic Board Replacement, Unscrew the battery connector cover: passo 16, imagem 2 %32
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
    Definitely make sure all three lobes of your tool are aligned before use (it’s a little harder to tell with this style of bit) and apply even and adequate pressure to ensure it grabs as you spin the driver to prevent disfiguring the lobes/slot of the screw head.
    Unfortunately my Y000 tool was perhaps not the best fit (tolerance a bit off) in these screws and I ended up stripping out the heads of all three of these. I started to panic but after I sanded the tip of my Y000 bit down a little with super fine grit (1000CW-C) sand paper to flatten the domed tip (visible with macro lens) and give it a bit more bite I was able to remove and reinstall without issue—in fact I had to remove and install them twice since I forgot my adhesive tape during reassembly, so the screws survived and the sanded bit worked.
    Erica - Responder
    +1 to above comment. I bought a cheap kit from Amazon and the Y000 screw driver is not good for this job. I’m concerned that I may have disfigured the heads and i type this comment in the midst of my fix :D Be gentle and assess if you can remove at least one screw with your driver before rummaging through all three and other similar screws holding display connector as well.
    Shan Potti - Responder
    Update to above comment. I got hold of a Y0.8 screw driver bit (lucky to find an ORIA screw driver kit in my office) and it works like wonders :) Now back to work…
  17. iPhone XR Logic Board Replacement, Disconnect the battery: passo 17, imagem 1 %32 iPhone XR Logic Board Replacement, Disconnect the battery: passo 17, imagem 2 %32
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  18. iPhone XR Logic Board Replacement, Unscrew the display connector cover: passo 18, imagem 1 %32 iPhone XR Logic Board Replacement, Unscrew the display connector cover: passo 18, imagem 2 %32
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
    What if the screw is damaged and you can’t get one out?
    Kashawn Benjamin - Responder
  19. iPhone XR Logic Board Replacement, Disconnect the digitizer: passo 19, imagem 1 %32 iPhone XR Logic Board Replacement, Disconnect the digitizer: passo 19, imagem 2 %32
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  20. iPhone XR Logic Board Replacement, Disconnect the display: passo 20, imagem 1 %32 iPhone XR Logic Board Replacement, Disconnect the display: passo 20, imagem 2 %32
    • Use the tip of a spudger to disconnect the display cable connector.
    The new display cable isn’t snapping in but I was just able to snap in the old one. Did I break the new one somehow?
    Andrew Pierson - Responder
    Same it is really frustrating, just keeps slipping up and its bound to get damaged
    Daniel Maldonado - Responder
  21. iPhone XR Logic Board Replacement, Unscrew the logic board connector cover: passo 21, imagem 1 %32 iPhone XR Logic Board Replacement, Unscrew the logic board connector cover: passo 21, imagem 2 %32
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
    Phillips screw 1.3 mm on last step is not working. The small clipped bracket has been damaged. This screw perhaps should be the first, before 1.2 Y000. - To be confirmed by others.
    Dmitri - Responder
    I’m not sure it makes much if any difference, but we went ahead and swapped the order for you guys. Thanks for your comments!
    Jeff Suovanen - Responder
    I just repaired another XR, and you are right! It doesn’t make any differnerce in the order these screws come out. I still damaged this fragile piece. As I work on more of these, I’ll figure out a way to remove this screw without damaging the clip. For now everyone, just use extra caution when removing the 1.3mm phillips screw! Thanks Jeff
    fabianowens -
    I’ve now done at least 6 of these so far and I have fairly consistent good results by taking the 2 Philips head screws out first, then doing the Y screws.
    Stow -
    Is this piece important for the repair if broken? I have broken it on a home repair. What is it used for? Is it a grounding connection or is it completely unimportant. More information needed please
    Squishy Horses - Responder
    I’m wondering that too. Is this piece important?
    Phillip Gross -
    My clip broke too! on iphone XR. Any word on necessity?
    Beth Buer - Responder
    I can confirm that taking out the 1.3 mm screw first then the 1.5 mm screw works the best. If done correctly, you should be able to to remove the rest of the screws and pull the panel off with the clip still attached to the panel. For reassembly, start with the 1.5 mm screw then the 1.3 mm screw.
    Carlos Oulman - Responder
    I don’t remove the small screw at all. I just slide out the metal cover plate and slide back in to reassemble.
    Kyaw-Zin Win - Responder
    this is what i have done as well. Care is still needed to avoid damaging this part. However, it is seemingly far less prone to damage or loss and thus less risky for this repair process.
    Justin Parsons -
    I too broke this shield. In looking over this problem I believe it’s best to loosen, but not remove, either screw first then the other. To be clear, loosen the red or yellow screw but only just to break it free, then the second screw. Then remove both and the others and the shield should remain in one piece. I put it back with the broken part (on the red screw) and made sure the two are in contact so there’s conductivity as these shields serve a purpose other than just holding in connectors. My phone works fine with this fix.
    pgrobin - Responder
    Is this small bracket important if broken??
    Phillip Gross - Responder
    Mine is broken and my apple pay doesn’t work. Something to do with NFC antenna this little clip??
    Marcos Fernández - Responder
    I'm guessing so. I replaced a screen on a phone I bought from a friend. I noticed this bracket was broken when I disassembled the phone but didn't think much of it. When I reassembled it my NFC also does not work. Bummer. A lot of people in these comments have asked if it is crucial that this bracket be connected. Can someone from iFixit or other please reply to those comments?
    Larry Jorgenson -
    On the 1.3 mm screw I actually chose not to remove it. I broke it loose then used the tip of the spudger to simply twist the bracket out of the way, with the screw still attached. Then I could remove the larger bracket.
    mpalma - Responder
    Kyaw-Zin is right because the shield contains of two tin parts. But there is another option:
    1. Unscrew the yellow and orange screws first.
    2. Lift the shield gently that it can turn about 20° anticlockwise.
    3. Open the red screw and let the shield turn with it the first degrees.
    Daniel Brehm - Responder
    The first time I did this repair, I didn’t see the comments ahead of time and broke the bracket, even removing the 1.3mm screws first. The second time I did the repair, I was prepared and being extra careful, but the simple act of turning the 1.3mm screw head was enough to break it. If I ever have to do this repair again, I’ll just leave the screw in and try to slide the plate out with the screw (and bracket, hopefully) still in tact, as per Kyaw-Zin Win.
    Debbie Thompson - Responder
    None of the screw driver bits I got fits the 1.3mm and 1.5mm screws. How do I remove them?
    Jonatious Joseph Jawahar - Responder
    Same issue as above. The bits provided in the kit do not work with the 1.3mm and 1.5mm screws
    Graham Hammell - Responder
    Further to above comment about bit not working. Had to go and purchase another PH000 from Home Depot and that worked
    I’ve broken that little bracket attached to the red screw. Is it important and can I get a replacement????? Thanks all
    steve.arfa - Responder
    Broken the clip. Is this important??
    kyledrumtutor - Responder
    Yikes, broke mine too. Oh god. Think perhaps the delicate 1.3mm should come out first when everything else is secure...
    Ronald - Responder
    Don't remove the 1.3 Phillips screw! Twisting this screw will break the smaller bracket that is clipped to the larger. Remove all the other screws. Block the smaller bracket from moving as you gently slide the larger bracket horizontally toward the battery until free. The smaller bracket can stay in place while the screen is replaced. When reassembling, support the small bracket by backing with a spudger or similar tool.
    doug68242 - Responder
    I just broke the smaller bracket also :( I didn´t notice these comments until now :(
    It looks like part of the antenna for NFC, as all except NFC works on my iPhone now.
    It should be repairable using some wire wrap wire, either twisted around the two screws that connected that part of the bracket (or soldered in place). I will try and report back if it works.
    Richard Croyle - Responder
    Success!! I managed to re-construct the small arm of the bracket by screwing the 1.3mm screw back in with some 0.3mm enamel wire soldered into what was left of the small bracket arm on the screw, then the other end of the enamel wire I wrapped under the 1.5 wire screw's head (enamel exposed to bare metal), then screwed both screws down. also I lifted up the small metal arm with a screw driver (to make sure it reconnects with the display grounding square) ..and NFC worked again (slightly different antenna pattern mind (need to place cards slightly higher up the rear of the phone). Anyway works again :)
  22. iPhone XR Logic Board Replacement, Disconnect the front sensors: passo 22, imagem 1 %32 iPhone XR Logic Board Replacement, Disconnect the front sensors: passo 22, imagem 2 %32
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
    During testing, make sure your proximity sensor is not on upside down, as it’s easy to connect upside down. Your phone will boot loop if it’s on incorrectly.
    Tristan England - Responder
  23. iPhone XR Logic Board Replacement, Remove the display assembly: passo 23, imagem 1 %32
    unclear if this is where screen removal ends
    I had the same question, but the answer is yes. Steps 21-30 are removing parts from the original screen that need to be reattached onto the new screen. You are no longer working inside the frame, but on the back of the screen itself.
    amclean78 - Responder
    I apologize for missing these comments initially, but yes that’s correct, the screen is removed now and the rest of the guide goes on to other parts, either in the phone or on the back of the screen. Good luck with the repair!
    Adam O'Camb -
    The alternate method of removing the battery should be highlighted as a standard option. There is so much more work and potential to damage the parts than if you left them in place and carefully with plenty of heat remove the battery. I so wish I had seen this before!
    Martin Kappeyne - Responder
  24. iPhone XR Logic Board Replacement, Rear-Facing Camera: passo 24, imagem 1 %32
    • Remove the two screws securing the rear camera cover:
    • One 1.6 mm Phillips screw
    • One 2.4 mm standoff screw
    • Standoff screws are best removed using an iPhone standoff bit and driver handle.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    if your camera is ok you can skip removing it - go to step 26
    Stow - Responder
    you will need to do step 23 though…..
    Stow -
  25. iPhone XR Logic Board Replacement: passo 25, imagem 1 %32
    • Lift the camera cover straight up and off of the camera.
  26. iPhone XR Logic Board Replacement: passo 26, imagem 1 %32 iPhone XR Logic Board Replacement: passo 26, imagem 2 %32
    • Use an opening tool or fingernail to disconnect the camera cable connector by prying it straight up from its socket.
  27. iPhone XR Logic Board Replacement: passo 27, imagem 1 %32 iPhone XR Logic Board Replacement: passo 27, imagem 2 %32
    • Insert the tip of a spudger at the top left corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
  28. iPhone XR Logic Board Replacement: passo 28, imagem 1 %32
    • Remove the rear-facing camera.
  29. iPhone XR Logic Board Replacement, Remove the SIM tray: passo 29, imagem 1 %32 iPhone XR Logic Board Replacement, Remove the SIM tray: passo 29, imagem 2 %32
    • Use a SIM tool to remove the SIM tray.
  30. iPhone XR Logic Board Replacement, Disconnect FPC’s: passo 30, imagem 1 %32 iPhone XR Logic Board Replacement, Disconnect FPC’s: passo 30, imagem 2 %32
    • Disconnect the remaining Front Panel Connectors
    • There are 5 FPC's near the iSight camera.
    • There are 4 FPC's near the SIM reader.
    • Be sure not to use too much pressure when disconnecting the FPC to avoid damaging the logic board,
  31. iPhone XR Logic Board Replacement, Remove the SIM reader: passo 31, imagem 1 %32 iPhone XR Logic Board Replacement, Remove the SIM reader: passo 31, imagem 2 %32 iPhone XR Logic Board Replacement, Remove the SIM reader: passo 31, imagem 3 %32
    • Remove the following screws:
    • 2.9mm standoff screw
    • 1.5mm Phillips #000
    • 1.6mm Phillips #000
    • Remove the grounding bracket
    • Pull the SIM reader
    • Be sure to push the black SIM push rod back in the rear housing before attempting to remove the SIM reader.
  32. iPhone XR Logic Board Replacement, Logic board: passo 32, imagem 1 %32
    • 2.9mm Standoff screw
    • 2.8mm Standoff screw
    • 1.8mm Phillips #000
  33. iPhone XR Logic Board Replacement: passo 33, imagem 1 %32 iPhone XR Logic Board Replacement: passo 33, imagem 2 %32 iPhone XR Logic Board Replacement: passo 33, imagem 3 %32
    • Pull the logic board from the rear housing.
Conclusão
58 outras pessoas executaram este guia.
iHelpU.Tech
Membro desde: 08/02/17
3.558 Reputação
Autoria de 5 guias
Equipe
iHelpU.tech Membro de iHelpU.tech
Business
Membros da 2
Autoria de 16 guias
19 comentários
if I replace the logic board will it remove a iCloud lock??????
caleb alvarez - Responder
TL;DR: Yes, it should but…
All of the phone’s memory is stored on the NAND flash memory with is soldered to the logic board. Replacing the iCloud-locked logic board with a logic board from a phone that does not have an iCloud lock will technically remove the lock.
A terrible analogy would be like if you had had a tumor (iCloud lock) in your brain (MLB) so your surgeon (you, the technician) performed a brain transplant. Replacing the brain would indeed get rid of the tumor. However, your body (The phone’s housing) would just become the person of whose brain was transplanted into your body.
The only true way to remove an iCloud lock is to obtain the Apple ID & Apple ID password of the original owner.
You just have to try to find a good logic board and trust that the seller is legit. (Easier said than done)
This guide was more intended for those that are attempting micro-soldering repairs. However, you can use the guide for whatever you need. :-)
iHelpU.Tech -
If i chanfe the logic board do i also have to swap the facial scan like the fingerprints on the prior iphone or all i gotta do is swap the boards
Ahmad Zia - Responder
Great question! From what I’ve experienced, the Face ID hardware is similar to touch ID hardware in that it is tied to the phone’s logic board. However, FaceID does seem a little more forgiving. The phone I’m currently using is an iPhone X that was severely damaged. I bought it off a customer and installed a new screen but Face ID did not work. A couple months later, I was using an app that made use of face ID hardware for facial recognition and mapping. I thought it wouldn’t work since FaceID wasn’t working on my phone. To my surprise, it worked just fine. I then tried setting up FaceID and it was able to activate and capture my face.
If you’re looking to refurbish a phone, assume FaceId won’t work without the original hardware. However, your milage may vary.
iHelpU.Tech -
Does the camera work even the face I'd doesn't work ?
Reynaldi Eko - Responder
From what I’ve seen, yes it does. However, your milage may vary. Make sure you check to see if your cameras are good before you replacing/repairing the logic board. I’ve already had an iPhone XS where the cameras and flashlight stopped working. Replacing the iSight camera seemed to do the trick.
iHelpU.Tech -
Front camera will function as normal, but no Face ID
Richard -
Hello.. I have a question,
I have been done replace the logicboard, when I test camera with potrait mode front camera doesn’t working properly, the picture is very dark and when I move my body or face the my picture in camera it’s very slow and lagy. It’s is normal issue sir if we swap the logicboard ???
And I found one issue again with the battery it show “Important Battery Message” and unable to verify, the battery health show service.
How to solve this issue sir? Many Thanks Before
Supri Apriyanto - Responder
Article regarding the battery: https://www.ifixit.com/News/apple-is-loc...
Have you tried reinstalling iOS? Be sure to backup your data first, as you will probably have to erase the phone. Let me know if that helps.
iHelpU.Tech -
What could be the issue on my XR the restarts randomly… It takes several attempts to boot normally. But when I opened any app, the phone shuts down again. There are panic-full logs in the data analytics logs. Factory reset, IOS restoration and DFU did not help. Any idea? TIA
Noel de Chavez - Responder
Unfortunately, it would be a shorter list if I told you what was unlikely to cause the iPhone XR to randomly reboot. Hopefully you have a computer or iCloud backup of the phone because I would suggest getting a different phone or talking to Apple. If data is needed, talk to a data recovery specialist like iPad Rehab. (Don’t expect Apple to even attempt to save your data).
iHelpU.Tech -
Hello, thanks for this helpful guide! Where can I get a replacement logic board?
Khawm Mung - Responder
I’m glad you found the guide helpful! There’s no magic shop to order a replacement logic board. If you can’t find one pre-vetted from a site like iFixit, you’ll have to try your luck with a resale site like eBay. I wish Apple was more open to repair and sold parts direct to consumers and shops. Then again, I also wish I had a pile of gold lol.
iHelpU.Tech -
How do you distinguish different types of strews?
Henry Liu - Responder
The different types of screws are denoted by color for each step. The size in millimeters give you the length of the screw measured by a digital caliper. Screw type is distinguished by the head of the screw. (Phillips #000)
iHelpU.Tech -
@ipoint The guide was made to show how to remove the logic board, in which is accomplishes. It was mainly intended as a reference for anyone wanting to fix the board itself via micro soldering. Feel free to use this guide to make your own guide on swapping FaceID hardware. It seems like you could use the reputation points anyways.
iHelpU.Tech - Responder
These guides are awesome! Just a little comment on terminology…
In step 27 - “Disconnect the remaining Front Panel Connectors.” The front panel has already been removed. FPC stands for Flexible Plastic Connectors. An alternative acronym is FFC which stands for Flat Flexible Connectors.
brandyballoon - Responder
where i can get logic board trusted quality
SOFIAN OU-sous - Responder
Do you Have motherboard for iphone xr and iphone 7 and iphone xs
Kagwa Samuel (Sam) - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 41
Últimos 7 dias: 257
Últimos 30 dias: 1,178
Duração total: 80,181
