Ir para o conteúdo principal
Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X
O que você precisa
  1. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Parafusos Pentalobe: passo 1, imagem 1 %32
    • Antes de começar, descarregue a bateria do iPhone abaixo de 25%. Uma bateria de íons de lítio carregada pode pegar fogo e/ou explodir, se perfurada acidentalmente.
    • Desligue o iPhone antes de iniciar a desmontagem.
    • Remova os dois parafusos pentalobe de 6,9 mm na borda inferior do iPhone.
    • Se os parafusos estiverem espanados ou danificados, substitua os parafusos.
    • Abrir a tela do iPhone comprometerá as vedações à prova d'água. Tenha à mão vedações de reposição se passar por essa etapa ou evite a exposição a líquidos se você remontar o iPhone sem substituir as vedações.
    There are 6.81mm long screws!
    Daniel - Responder
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - Responder
    same situation here
    kaunomarcius - Responder
    Same issue for me too, how do I get the stripped screw out?
    patronics - Responder
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - Responder
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - Responder
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - Responder
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - Responder
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - Responder
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - Responder
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - Responder
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - Responder
  2. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Fazer uma marca em suas palhetas: passo 2, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Fazer uma marca em suas palhetas: passo 2, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Fazer uma marca em suas palhetas: passo 2, imagem 3 %32
    • Se você inserir uma palheta de abertura muito fundo, você pode danificar o seu dispositivo. Execute esta etapa para marcar a palheta e evitar danos.
    • Meça 3 mm a partir da ponta e marque a palheta com um marcador permanente.
    • Você também pode marcar as outras pontas da palheta com medidas diferentes.
    • Como alternativa, prenda uma moeda com fita adesiva em uma palheta, deixando 3 mm de ponta.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Responder
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Responder
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Responder
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Responder
  3. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Coloque fita adesiva sobre todas as rachaduras: passo 3, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Coloque fita adesiva sobre todas as rachaduras: passo 3, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Coloque fita adesiva sobre todas as rachaduras: passo 3, imagem 3 %32
    • Se o seu iPhone tiver uma tela rachada, mantenha as rachaduras sob controle e evite danos corporais durante o reparo colocando fita adesiva sobre o vidro.
    • Coloque tiras sobrepostas de fita adesiva transparente sobre a tela do iPhone até que toda a superfície fique coberta.
    • Use óculos de segurança para proteger seus olhos de qualquer vidro que possa ser liberado durante o reparo.
    • Se não conseguir fazer com que a ventosa grude nas próximas etapas, dobre um pedaço de fita adesiva resistente (como fita adesiva vedante) na forma de uma pega e levante a tela com ela.
    • Se tudo mais falhar, você pode colar a ventosa na tela com supercola.
  4. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Instruções com o Anti-Clamp: passo 4, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Instruções com o Anti-Clamp: passo 4, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Instruções com o Anti-Clamp: passo 4, imagem 3 %32
    • As próximas três etapas demonstram o Anti-Clamp, uma ferramenta que projetamos para facilitar o procedimento de abertura. Se não estiver usando o Anti-Clamp, pule três etapas para um método alternativo.
    • Para obter instruções completas sobre como usar o Anti-Clamp, consulte este guia.
    • Puxe a pega azul para trás para destravar os braços do Anti-Clamp.
    • Deslize os braços pela borda esquerda ou direita do iPhone.
    • Posicione as ventosas próximo à borda inferior do iPhone - uma pela frente e a outra pela traseira.
    • Aperte as ventosas uma contra a outra para aplicar sucção na área desejada.
    • Se você achar que a superfície do iPhone é muito escorregadia para o Anti-Clamp se prender, você pode usar fita para deixar a superfície mais aderente.
  5. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 5, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 5, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 5, imagem 3 %32
    • Puxe a pega azul para a frente para travar os braços.
    • Gire a pega 360 graus no sentido horário ou até que as ventosas comecem a se esticar.
    • Certifique-se de que as ventosas permaneçam alinhadas uma com a outra. Se elas começarem a ficar desalinhadas, solte um pouco as ventosas e realinhe os braços.
  6. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 6, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 6, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 6, imagem 3 %32
    • Aqueça uma bolsa térmica iOpener e passe-a pelos braços do Anti-Clamp.
    • Você também pode usar um secador de cabelo, uma pistola de ar quente ou uma chapa quente - mas calor extremo pode danificar o visor e/ou a bateria interna, portanto, proceda com cuidado.
    • Dobre a bolsa térmica iOpener de modo que ela fique sobre a borda inferior do iPhone.
    • Aguarde um minuto para que o adesivo tenha a chance de se soltar e apresentar uma vão para a abertura.
    • Insira uma palheta de abertura sob a tela e o painel de plástico, mas não abaixo da própria tela.
    • Se o Anti-Clamp não formar espaço suficiente, aplique mais calor na área e gire a pega um quarto de volta.
    • Não gire a pega mais do que um quarto de volta de cada vez e espere um minuto entre cada volta. Deixe que o Anti-Clamp e o tempo façam o trabalho por você.
    • Pule as próximas três etapas.
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Responder
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  7. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 7, imagem 1 %32
    • O aquecimento da borda inferior do iPhone ajudará a amolecer o adesivo que prende a tela, facilitando a abertura.
    • Use um secador de cabelo, uma pistola de ar quente ou prepare uma bolsa térmica iOpener e aplique-o(a) na borda inferior do iPhone por cerca de um minuto para amolecer o adesivo que se encontra por baixo.
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - Responder
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - Responder
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - Responder
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - Responder
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - Responder
  8. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 8, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 8, imagem 2 %32
    • Se estiver usando uma ventosa de sucção única, aplique-a na borda inferior do telefone, evitando a parte curva do vidro.
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - Responder
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - Responder
  9. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 9, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 9, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 9, imagem 3 %32
    • Puxe a ventosa para cima com pressão firme e constante para criar um pequeno vão entre a tela e a estrutura.
    • Insira uma palheta de abertura no espaço sob a moldura de plástico da tela, mas não debaixo da própria tela.
    • O adesivo à prova d'água que mantém a tela no lugar é muito forte; a formação dessa abertura inicial requer uma quantidade significativa de força. Se estiver com dificuldade para abrir um vão, aplique mais calor e balance a tela para cima e para baixo para amolecer o adesivo, até se formar um vão de tamanho suficiente para inserir a ferramenta.
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - Responder
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - Responder
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - Responder
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - Responder
  10. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 10, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 10, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 10, imagem 3 %32
    • Deslize a palheta de abertura pelo canto inferior esquerdo e pela borda esquerda do iPhone, cortando o adesivo que mantém a tela no lugar.
    • Não insira a palheta mais do que 3 mm, pois isso pode danificar os componentes internos.
  11. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Informações da tela: passo 11, imagem 1 %32
    • Há cabos sensíveis ao longo da borda direita do iPhone. Não insira a palheta aqui, pois isso pode danificar os cabos.
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - Responder
  12. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 12, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 12, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 12, imagem 3 %32
    • Insira novamente a palheta na borda inferior do iPhone e deslize-a para cima no lado direito para continuar separando o adesivo.
    • Não insira a palheta mais do que 3 mm, pois isso pode danificar os cabos da tela.
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
  13. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 13, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 13, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 13, imagem 3 %32
    • A borda superior da tela está fixada com cola e clipes.
    • Deslize a palheta de abertura pelo canto superior da tela e, ao mesmo tempo, puxe ou movimente a tela com cuidado para baixo na direção do conector Lightning.
    • Os clipes romperão se você usar muita força. Trabalhe com cuidado e seja paciente.
    • Não insira a palheta mais do que 3 mm, pois isso pode danificar o conjunto de sensores do painel frontal.
    • Deslize a palheta para o canto oposto e corte todo o adesivo restante que esteja prendendo a tela.
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - Responder
  14. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 14, imagem 1 %32
    • Puxe a pequena lingueta da ventosa para removê-la do painel frontal.
  15. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 15, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 15, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 15, imagem 3 %32
    • Abra o iPhone virando a tela para cima a partir do lado esquerdo, como se fosse a contracapa de um livro.
    • Não tente separar totalmente a tela ainda, pois vários cabos planos frágeis ainda a conectam à placa lógica do iPhone.
    • Conforme mostra a foto, verifique se a moldura se solta com a tela e não fica presa no dispositivo.
    • Encoste a tela em algo para mantê-la apoiada enquanto estiver trabalhando no telefone.
    • Durante a remontagem, coloque a tela em posição, alinhe os clipes ao longo da borda superior e pressione cuidadosamente a borda superior antes de encaixar o restante da tela. Se ela não se encaixar facilmente e você não ouvir um click, verifique a condição dos clipes ao redor da tela e certifique-se que eles não estejam tortos.
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - Responder
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - Responder
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - Responder
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - Responder
  16. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Conjunto da tela: passo 16, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remova os cinco parafusos Y000 que prendem o suporte do conector da placa lógica, com os seguintes comprimentos:
    • Três parafusos de 1,1 mm
    • Um parafuso de 3,1 mm
    • Um parafuso de 3,7 mm
    • Durante o reparo, rastreie cada um dos parafusos e certifique-se de que eles voltem exatamente para o local de onde vieram, para evitar danos ao iPhone.
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - Responder
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - Responder
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - Responder
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - Responder
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - Responder
  17. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 17, imagem 1 %32
    • Remova o suporte.
    • O suporte pode estar ligeiramente colado no lugar. Levante-o com cuidado, mas com firmeza, para separá-lo.
    • Durante a remontagem, este é um bom momento para ligar o iPhone e testar todas as funções antes de vedar a tela em sua posição. Certifique-se de desligar o iPhone completamente antes de continuar o trabalho.
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - Responder
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - Responder
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - Responder
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
  18. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 18, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 18, imagem 2 %32
    • Com a ponta pontiaguda de uma espátula ou uma unha limpa, erga o conector da bateria de seu soquete na placa lógica.
    • Tente não danificar a vedação de silicone preta que envolve essa e outras conexões da placa. Essas vedações oferecem proteção extra contra a entrada de água e poeira.
    • Vire o conector ligeiramente para fora da placa lógica para evitar que ele entre acidentalmente em contato com o soquete e alimente o telefone com energia elétrica durante o reparo.
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - Responder
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - Responder
    Thanks, already did it)
    Stephen Hedrick -
  19. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 19, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 19, imagem 2 %32
    • Com a ponta pontiaguda de uma espátula ou a unha, desconecte o conector do conjunto de sensores do painel frontal.
  20. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 20, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 20, imagem 2 %32
    • Com a ponta pontiaguda de uma espátula ou a unha, desconecte o conector do cabo do painel OLED.
    • Para reconectar conectores press-fit como este, alinhe e pressione cuidadosamente um lado até que ele se encaixe e, em seguida, repita no outro lado. Não pressione no centro. Se o conector estiver desalinhado, os pinos podem entortar, causando danos permanentes.
    Snap ‘em in like little Legos.
    Ray Johnson - Responder
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - Responder
  21. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 21, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 21, imagem 2 %32
    • Com a ponta pontiaguda de uma espátula, retire o conector do cabo do digitalizador de seu soquete.
    • A localização rebaixada desse conector dificulta a reconexão. Não tenha pressa e alinhe-o com cuidado e, em seguida, pressione-o gentilmente no lugar com a ponta do dedo - primeiro de um lado, depois do outro. Você deverá sentir o clique de ele se encaixando.
    • Se alguma parte da tela não responder ao toque após o reparo, desconecte a bateria e instale de novo esse conector, certificando-se de que ele se encaixe totalmente e de que não haja poeira nem nenhuma outra obstrução no soquete.
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - Responder
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - Responder
  22. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 22, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 22, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 22, imagem 3 %32
    • O cabo conector flex do conjunto de sensores do painel frontal está ligeiramente colado.
    • Levante o cabo com cuidado até que o adesivo se separe.
    Do this sensor affect face id?
    bonglkv - Responder
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - Responder
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - Responder
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - Responder
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - Responder
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - Responder
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - Responder
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - Responder
  23. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 23, imagem 1 %32
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - Responder
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - Responder
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - Responder
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - Responder
  24. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X, Conjunto de alto-falante auricular e sensores da parte frontal: passo 24, imagem 1 %32
    • Remova o parafuso Y000 de 1,2 mm na parte traseira do conjunto do visor, próximo ao conector da câmera de infravermelho.
    Not sure as of what to do now, I have stripped this screw.
    Kelvin - Responder
    It might be your driver tip that is no good. Try a new driver tip Y000
    carol - Responder
    when I opened my iPhone the screw was already stripped, I had the phone once at an Apple store for repair about 2 years ago. Had not opened it in between so it seems they stripped the screw there or it came like that from the factory. Any ideas? I don’t want to try and force it out.
    Be careful: the metal clip beneath this screw it’s really small, make sure not losing it.
    Luca Ciprian - Responder
    Steps 19 and on are all on the screen you just removed. Not the phone side. I didn’t look closely at the image and just went for the screw in roughly the same place on the phone body side. First warning sign it’s a phillips - but more importantly I was working on the entirely wrong piece. I guess you’ll probably figure it out faster than I did.
    Big Nerd - Responder
    FYI: My iphone XS has a slightly different screw position for the one shown to have a “clip”. There is no clip for this screw on mine. Maybe a rev update because of the clip getting lost and being hard to reinstall?
    FYI - The sensor assembly of the replacement looks a bit different from my original one. The screw is located further to the right on the original. As a result, I am unable to attach the sensor assembly on the replacement part, because the fixture is at a different position.
    Unfortunately, there’s nothing I can do about it apart asking for a refund.
    Screws at my Iphone X are normal,but even w heat,i cant take them off,and even the strongest member of my family cant do this
    Matej Sedivec - Responder
  25. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 25, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 25, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 25, imagem 3 %32
    • Sob o parafuso que você acabou de remover, há um pequeno clipe metálico de aterramento. Se ele ainda não tiver saído junto com o parafuso, remova-o agora.
    • Durante a remontagem, oriente o clipe conforme mostra a foto. Segure o clipe na posição enquanto posiciona e aperta o parafuso.
    sin ese clip la señal wifi se recibe a duras penas
    Harizola Taberna Margari - Responder
    Is there a way to just buy the gold grounding clip because my phone cannot search for wifi anymore!
    Anonymous - Responder
    Is there any way we buy the ground metal clip separately please if there’s a way to get it emailed me
    Sisthanu Iman - Responder
    Reinstalling this clip + screw is super hard =P
    Josh Estelle - Responder
    It is pretty difficult without using a zoom in. A 2nd iphone camera zoomed in at 8x while using magnetic screwdrivers makes the job a little easier
    Bill McNamara -
    Screw Gasket Ear Speaker for Apple iPhone X Replacement Repair Phone Part Speak
    riosbenny09 - Responder
    This looks different on my iPhone X. There’s no clip. It turns out that the replacement screen is NOT compatible with my iPhone. See my comment on Step 23. Must be a different HW revision. The whole front sensor assembly casting is a bit different. After replacing 2 screens of older iPhone generations this is my first failure due to HW incompatibility. From here on forward I probably won’t attempt another major smart phone repair. Technology is getting to complex for DIY. Will buy an iPhone 13 Pro with insurance (even though it’s utterly overpriced and I always like the DIY challenge)…
    it’s not technology that’s getting more advanced, it’s apple creating more barriers between a DIY repair vs funneling your hard earned dollar into apple care and the Genius Bar
    aburningstariv -
    I did the same thing here - its the x vs xs and my partner ordered the part
    I ripped off the side clips and ones in wrong place (put the old screen next to it - and rip them off with needle nose plyers (in a rolling motion so you get each solder one at a time)). the smaller clips that had enough room i left.. then i could force the screen on.
    And its working ...... lets see for how long - the sealant and small clips seem to be holding it together ok
    Archie Ko -
    Que pasa si no pones ese clip?
    ferxi sabee - Responder
  26. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 26, imagem 1 %32
    • Remova mais dois parafusos Y000 que prendem o conjunto do alto-falante/sensores:
    • Um parafuso de 1,6 mm
    • Um parafuso de 1,3 mm
    What do you do if the 1.6mm tripoint screw won’t come out…? I think it may be stripped :(
    Salvatore Boenzi - Responder
    You could try using an old screwdriver & carefully adding a dab of superglue to the screw to attach it to the screwdriver, Then the screw may come out, Superglue’s strength is holding 2 pieces together when the stress point is pulling the 2 pieces away from each other. Superglue becomes surprisingly easy to break when twisting the 2 pieces. So be careful since the rotation of the screw will put the stress point at the weakest of the glue’s strength.
    Sandman619 - Responder
    I would suggest:
    1. Try a small precision flat head, a good quality one, I bought some that were supposed to be to remove stripped screws, about 20-30 bucks for 4 or 5 of them, and they have saved my butt many times.
    2. I have been able to remove stripped screws with wire cutters. Or you can try some vamp pliers but they are probably too large for this situation.
    3. If the last two fail, the course of action is to basically destroy the head of that screw (assuming you are removing the stuff you need for your new lcd, which is very likely) they have drill bits called easy outs or screw removing drill bit, which is a drill bit with the spiral going the opposite direction (for a screw that tiny you can take a small drill bit, cut and sharpen the end that normally has no spiral, I have made that work in the past) the point is that as you drill in, the drill bit is digging and moving counterclockwise, so at some point as it digs in it will get “stuck” and keep spinning go the screw, thus removing it.
    Victor Miranda - Responder
    what to do if during assembly the 1.6mm doesn’t want to go in it’s hole in the new screen but it fits perfectly in the old one??
    Khalil - Responder
  27. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 27, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 27, imagem 2 %32
    • O alto-falante auricular está ligeiramente colado.
    • Com uma espátula, levante cuidadosamente a borda superior do conjunto do alto-falante e vire-o para baixo, afastando-o da borda superior da tela.
    • O alto-falante permanece conectado por meio de um cabo conector flex muito fino. Tenha cuidado para não esticar ou danificar o cabo.
    i damage the cable, where can i buy a replacemnt
    Haoyu Li - Responder
  28. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 28, imagem 1 %32
    • Aplique um secador de cabelo, uma pistola de ar quente ou um iOpener na parte superior frontal do visor por cerca de um minuto para amolecer o adesivo que fixa os sensores.
    que temperatura debe tener una estacion de calor para hacer el trabajo del iopener
    mismac - Responder
    I could not have done this without the iOpener, it was worth the investment!
    Bill Debevc - Responder
  29. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 29, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 29, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 29, imagem 3 %32
    • Passe cuidadosamente a borda plana da espátula por debaixo do cabo conector flex, que fica abaixo do microfone.
    • Faça movimentos de vai-e-vem suaves para separar o microfone, tomando cuidado para não esticar ou danificar o cabo conector flex.
    • Se necessário, use a ponta pontiaguda da espátula para terminar de separar o microfone de seu entalhe no painel frontal.
  30. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 30, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 30, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 30, imagem 3 %32
    • Vindo da esquerda para a direita, deslize uma palheta de abertura por debaixo do cabo conector flex e por debaixo do módulo do sensor de proximidade + flood illuminator.
    • Faça movimentos rápidos de vai-e-vem e levante com cuidado, separando o módulo de seu entalhe no painel frontal.
    • Para abrir acesso, pode ser útil levantar e afastar o alto-falante. Apenas tome cuidado para não puxar o cabo conector flex fino enquanto estiver trabalhando.
    i can i purchase this part
    M. Brown - Responder
    yes mr.brown, you can
    MadMan2207 - Responder
    if you interrupt a small part of that black tape, is the piece of Face ID/micro phone unrecoverable?
    green_g - Responder
  31. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 31, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 31, imagem 2 %32
    • Com uma pinça, faça movimentos rápidos de vai-e-vem no sensor de luz ambiente e retire-o do entalhe na tela.
    • O sensor permanece conectado ao restante do conjunto de sensores por meio de um cabo conector flex muito fino. Tenha cuidado para não esticar ou danificar o cabo.
  32. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 32, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 32, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 32, imagem 3 %32
    • Se você tiver conseguido remover todo o sensor de luz ambiente, conforme mostrado na primeira foto, passe para a próxima etapa abaixo.
    • Se a tira branca do difusor se soltar e permanecer embutida no visor, como mostrado na segunda foto, você precisará alavancá-la cuidadosamente ao longo da borda superior usando uma lâmina fina ou uma ferramenta de alavanca. Uma nova aplicação de calor pode facilitar um pouco essa tarefa.
    • Durante a remontagem, instale primeiro o difusor no visor, certificando-se de que ele esteja voltado para a direção correta (o lado voltado para a frente é mostrado na primeira imagem e o lado voltado para trás é mostrado na terceira).
    • Em seguida, coloque o sensor de luz ambiente em cima do difusor. Você precisará segurar o sensor na posição enquanto instala os parafusos que prendem o conjunto alto-falante/sensores. Quando os parafusos estiverem apertados, o sensor permanecerá no lugar e funcionará normalmente.
    quá rõ ràng, cảm ơn ifixit
    Dang Tuan - Responder
    In my case the diffuser came out with the light sensor, but not completely. A layer of the diffuser was left behind in the recess. We will see how it goes. ;) I will report back.
    what colour is the diffuser
    James Thomas (Tom) - Responder
    also can you show the position of sensors going back into the new screen
  33. Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 33, imagem 1 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 33, imagem 2 %32 Substituição do conjunto de alto-falante auricular e sensores da parte frontal do iPhone X: passo 33, imagem 3 %32
    • Remova o conjunto do alto-falante auricular e de sensores frontais.
    • Durante a remontagem, verifique a posição do módulo de plástico preto que contém esses componentes:
    • Sensor de proximidade
    • Flood illuminator
    • O módulo deve ser posicionado de modo que esses componentes não sejam obstruídos por nenhum adesivo.
    there was no bracket on my new screen I purchased from here.. am I supposed to heat up and remove the old one, or was their supposed to be one on the new screen ??
    0perationguttertech - Responder
    @br0k3nilluzion If your new display didn’t come with a front camera frame, you can (and should) remove the old one from your broken display and transfer it over. Use heat and careful wiggling/prying to remove it—and if it’s stubborn, add a few drops of isopropyl alcohol. Hope this helps!
    Jeff Suovanen - Responder
    Does face-id stop working if the black plastic separates from the flex(The orange and red dot)?
    tharshan91 - Responder
    If the black plastic piece with the flood illuminator and the proximity sensor is separated from the flex cable, then Face ID will definitely not work. Be very careful not to damage any of the parts in the front sensor assembly.
    Adam O'Camb -
    There is some sort of a tape in front of the flood illuminator which is not present on the replacement screen! Is that gonna cause a problem too?
    BTW, it’s so difficult to position the front camera frame without glue. I guess it takes a few attempts of trial and error!
    shoeib - Responder
    It might not cause any major problems, but there’s a chance that it could effect FaceID functionality. If possible, transfer the tape from the old screen to the new one.
    Adam O'Camb -
    I find it better, regardless of if your new screen comes with the transparent front camera frame, to remove the front sensor assembly from the old screen with the frame, and lifting up the whole assembly using the frame. That way you do not need to apply heat directly to the fragile assembly, but apply it to the other side, the front of the screen at the top, instead, to soften the frame adhesive. The frame is then usually easy to pry loose using a narrow spudger, and comes off cleanly. After that it is much easier to remove the sensors and microphone from the frame, no heat needed usually. And if your new screen doesn’t come with the frame, just plonk the whole frame/sensor assembly down in the right place, and boom, Bob’s your uncle.
    Lars - Responder
    Hello I have an iPhone X i Bought it in 2019 with Face ID not working ( not available try later ) I think the screen was changed with another original , tru tone Off , Als off no auto brightness (and the PROXIMITY SENSOR too ! ) no black screen in calls, i would like to ask u if the earpiece speaker flex was changed with another one (all components ) not the original , did proximity sensor still work ?? Because I don’t know is the original flex of my iphone or not ? I found some scratches in the flex it appears to have small cut so I don’t know the PROXIMITY SENSOR not working because there are a small cut in the flex or because the flex is not the same ?? And if the flex is not the original it can disable (proximity sensor)too not only flood and als ?? Thank you
    Ach - Responder
    Yes it should still work. If you change the assembly to one that isn’t original to that iPhone X everything except the FaceID should still work - I have done so several times for clients. So the reason for yours not working is probably the same small scratches and cuts you have seen. The cable is a bit fragile and some of the copper leads running through it are extremely thin.
    Lars -
    To keep True Tone function on the replacement screen you’ll need a chip data programmer EEPROM to copay data from the old screen onto the new one. There a device called JC-V1 which should do the trick.
    Yousef Ghalib - Responder
    Screen glitching slightly after changing the screen. Any suggestion to what it can be?
    Tim Morell - Responder
    Tim. I had a glitchy screen as well. It would force touch out of nowhere, and “ghost touch” every now and then. Eventually, the top half of the screen stopped responding. Reach out to customer service ASAP. You may have a defective screen.
    Alex Hurtado -
    My front ear speaker not working . The mic it’s working . Apple said you have to replace all the screen to fix the ear speaker because it’s connected with one cable all together. If I buy the speaker and change it myself it will work after or I’m getting into trouble?
    josh - Responder
    I have the same problem. I have the same problem. how did you solve?
    xX_Sn4k3x_Xx - Official -
    Be sure to remove the blue protective film from the BACK of a replacement screen.
    Jim Breef - Responder
    Thank you so much for this. It does not look at all like it needs to be removed.
    Pol Llovet -
    Thank you, Jim, came here just to look for that advice!
    seth hollub -
    can this piece assembly cause for the back camera and flashlight not work? All I did was change the screen and transfer this earpiece and it says warning sign that the flashlight needs to cool down and back camera not working
    disregard my last post, problem solved on my end customer had a bad back camera due to bad fall and so i replaced it and now the back camera and flashlight works. :)
    Hello I replaced today the second time iphone x display. The first time after a while the front camera stopped working. Today mounted the second time the display and the front camera works, while the rear one does not work. What can I do? Thanks
    Mimmo Cordola - Responder
    if you interrupt a small part of that black tape, is the piece of Face ID/microphone unrecoverable at all?
    green_g - Responder
Conclusão
Compare a sua nova peça de reposição com a peça original - pode ser que você precise transferir componentes remanescentes ou remover suportes adesivos da nova peça antes de instalá-la.
Para a remontagem de seu dispositivo, execute os passos acima na ordem inversa.
Leve o seu lixo eletrônico para um ponto de recolha ou uma recicladora certificada.
O reparo não está indo conforme o planejado?Confira a nossa comunidade de Respostas para obter ajuda na solução de seu problema.
88 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
en pt
100%
Udo Baingo está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Adam O'Camb
Membro desde: 04/11/15
196.113 Reputação
Autoria de 416 guias
23 comentários
Is it possible to fix the ““Face ID Is Not Available” problem? There seems to be a problem with the TrueDepth camera. Thanks!
Alejandro D - Responder
@alejandrod I’m afraid Face ID won’t work if this part is replaced. As stated in the introduction, this component is paired to the logic board from the factory (similar to the home button on earlier iPhones). Currently, if you need to replace this part, you’ll have to sacrifice Face ID, or else pay Apple directly to perform the repair. (They have a software calibration tool that pairs the new part to your phone to re-enable Face ID, but they don’t share it with anyone outside of Apple.)
Jeff Suovanen -
The flex cable was too bent, and now is broken. I’m going to buy another flex cable, but… Are there any ways to recover the Face ID functionality? Desoldering some components from the old one and weld them in the new flex cable?
Andrea Giacon - Responder
Flex cables can be repaired by a skilled microsolderer. It’s not a DIY however. If it’s a phone you care about, you’ll want to find yourself a good repair shop with the right equipment and skills. Apple can also repair it, but they will most likely just charge you $279 to replace the entire screen.
Jeff Suovanen -
My proximity sensor is defective and puts my phone in a boot loop when connected. To replace that, would I need to use a skilled microsolderer to replace that?
oosaghae - Responder
My earpiece is broken would replacing mean that I’m sacrificing Face ID?
Mujtaba Suhrawardy - Responder
Just did mine, and yes, my face ID doesn’t work anymore.
Dane Frederick -
Hey does anyone know what’s wrong with my Iphone X. I thought I had a blown ear speaker. So I just replaced the assembly, but after reassembling it doesn’t sound any different. Anyone speaking is extremely quiet. And yes my Bluetooth is off, no I don’t have any headphones in it. and the volume is all the way up. Any other ideas what is happening? It has been a major inconvenience to have to put everyone on speaker phone just to talk to them.
Dane Frederick - Responder
Have you checked the speaker grille/mesh to make sure it’s clean? They can get clogged with pocket lint over time, blocking sound from the speaker.
Jeff Suovanen -
شكرا علي كلشيء
Corva Loco - Responder
Hi All,
I replaced the screen on the iPhone X and now the camera and face ID don’t work. The camera app is black when I open it. I can’t test the proximity sensor because there is no cell service on the phone. I assumed I damaged the flex cable so I put a new one in and same result.
I put the original flex back on the original screen and same result. I am not sure if face ID or the camera was working before the repair. I normally check what is working and what isn’t, but I forgot to this time.
Thanks!
Mitch - Responder
Hey i was repair my iphone x battery when this broke off. i bought a new earpiece thing and the sensor part but i heard that apple pairs specific parts to the logic board so if i replace it will the mic still work?
Mak - Responder
I lost the screw and grounding clip. Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ Any ideal where I can get the screw and grounding clip?
Melvin Hamill - Responder
Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ I have lost the screw and grounding clip. Any ideal where I can find the screw and grounding clip/
Thank you
MEL
I have replaced the battery, the dock connector and this component and I forgot to install the grounding clip while closing the phone. Now everything works expect the charging; the phone recognizes the charger as an accessory but it does not charge at all. It charges only if it is not powered on (without showing any charging symbol, by the way). Do you know if this might be due to this missing grounding clip? Thanks!
Andrea Giammanco - Responder
Hola, con este proceso mi face id dejará de funcionar?
Saludos desde México!
Horlando Anzures Quiroz - Responder
Correcto, no funcionará
Terranova -
Si el Face ID deja de funcionar.
Terranova - Responder
What adhesive do you recommend for reattaching the earpiece speaker on to the replacement display?
mcvtech - Responder
I have iPhone X and the ear speaker not working. But I have one more iPhone X with cracked screen. Can I remove the ear speaker from the second  iPhone and replace it to my iPhone? Is the Face ID will work after if it’s original Apple part?
josh - Responder
Can I replace the earpiece speaker without also replacing the front sensor assembly?
Rosie Tabachnick - Responder
The earpiece flex is cut a little so my ear speaker stopped working is there any way to do this
black emmah - Responder
Could you recommend someone near me that can repair a flex cable? Westfield,Massachusetts
Louis - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 41
Últimos 7 dias: 240
Últimos 30 dias: 1,093
Duração total: 201,696
