Introdução
Our high quality repair guide now in english!
Back up all your data before the repair, and touch something metal, like a radiator to get rid of any static charges. The repair is a little more difficult and you need 60-90 minutes.
We recommend these tools for this repair: Pentalobe screwdriver, Phillips screwdriver, Y-type screwdriver, pick, suction cup, spatula, tweezers and spudger. You also need a heat gun to unglue the display.
The Y-type screws have also been called tri-point or tri-wing screws. Tri-point screwdrivers don't fit right and can strip your screw heads. Use a Y-type screwdriver that fits well (Wiha Picofinish Y000).
O que você precisa
Instruções em vídeo
23 outras pessoas executaram este guia.
5 comentários
are we able to repair ourselves or do we need to send to apple directly. unlike other iPhones i have been told that aftermarket parts wont work
James Turner - Responder
Hola, en dond s puede adquirir la pantalla del iPhone X ??.
Fernando - Responder
Where can you buy the iphone x screen?
actually, we do! [produto vinculado ausente ou desativado: IF377-000] we have a nice step by step guide too. Substituição da tela do iPhone X
Aiden -
replacement of rear camera of iphone x
pankaj - Responder
