Ir para o conteúdo principal
iPhone X Rear Camera Lens Replacement
  1. iPhone X Rear Camera Lens Replacement, iPhone X Rear Camera Lens Replacement: passo 1, imagem 1 %32 iPhone X Rear Camera Lens Replacement, iPhone X Rear Camera Lens Replacement: passo 1, imagem 2 %32
    • If the camera glass is broken, remove the broken glass pieces from the camera housing.
    • Remove the broken glass around the camera lens area, then clean the contours of the camera lens area.
  2. iPhone X Rear Camera Lens Replacement: passo 2, imagem 1 %32 iPhone X Rear Camera Lens Replacement: passo 2, imagem 2 %32
    • Attach the new rear camera glass with adhesive or use two drops of clear superglue on the sides of the camera housing.
    • Position the replacement camera lens in the camera lens area using precision tweezers.
    • Be extremely precise while doing this! You do not want to have to clean up and re-apply the superglue that you may have smeared when you aligned the camera glass wrong!
  3. iPhone X Rear Camera Lens Replacement: passo 3, imagem 1 %32
    • Apply light pressure on the camera lens to secure the lens glass to the camera housing.
    • You can now test your rear camera to check the sharpness of your photos and videos.
Conclusão
Congratulations! You have successfully replaced the camera lens on your iPhone X. Clean the lens with a microfiber cloth and you should be able to shoot videos and take pictures normally again.
39 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
cPix
Membro desde: 06/14/16
3.971 Reputação
Autoria de 8 guias
8 comentários
It was great to see…
Hizbur Rahman - Responder
It is not that easy because of the tough adhesive. it is impossible to remove the glass without heating it, but be careful the camera lenses got damage of to intensive heat. Better remove the camera before tiny pieces of glass could harm the functionality.
BSlash - Responder
Will the device still be waterproof after this repair? (provided the repair is done correctly)
George Downs - Responder
Bonjour,
Pour information : les iPhone ne sont pas étanches ! Même si les publicités laissent penser le contraire, il faut savoir que les iPhone ne sont pas étanches, pour preuve : il suffit de lire les conditions de garantie de chez Apple qui stipulent bien : “La présente Garantie ne s’applique pas : ... aux dommages causés par un accident,... une exposition à un liquide, au feu, à un tremblement de terre ... “
Donc, que ce soit après une réparation ou avant la réparation, votre iPhone n’est pas étanche, les différents joints “d’étanchéité” présents dans l’iPhone le protège principalement des poussières fines et des petites projections de liquide (genre : micro gouttelettes d’eau) .
Vous pouvez trouver ces joints sur cPix.fr ainsi que les pièces détachées et les outils pour réparer votre iPhone X
Mais n’oubliez pas, il n’est pas étanche ;-)
cPix - Responder
This is the worst repair guide on this website. . Not enough information on this guide to properly do the repair
berningchase - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 101
Últimos 30 dias: 512
Duração total: 147,889
