Ir para o conteúdo principal
Introdução
Follow this guide to remove and replace the logic board for the iPhone SE 2020.
Note: Each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  3. Apply a suction cup to the lower half of the front panel, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  5. Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place. Stop near the top left corner of the display. Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel. Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert the pick very far, or you may damage the display cables along this side of the iPhone. Insert it only a few millimeters, or about the width of the display bezel.
  7. Gently pull up on the suction cup to lift up the bottom edge of the display. Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  8. Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  9. Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case. Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  10. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board. Lean the display against something to keep it propped up while you're working on the phone.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • Remove four Phillips screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • Two 2.8 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    • Remove the bracket.
  11. Use the point of a spudger to pry the battery connector out of its socket in the logic board. Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    • Use the point of a spudger to pry the battery connector out of its socket in the logic board.
    • Bend the battery connector cable slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  12. Use the point of a spudger to pry the lower display connector out of its socket. To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • Use the point of a spudger to pry the lower display connector out of its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  13. Use the point of a spudger to disconnect the second lower display cable. Use the point of a spudger to disconnect the second lower display cable.
    • Use the point of a spudger to disconnect the second lower display cable.
  14. Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector. Remove the bracket.
    • Remove the three 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
  15. Use the point of a spudger to disconnect the  front panel sensor assembly connector. Use the point of a spudger to disconnect the  front panel sensor assembly connector.
    • Use the point of a spudger to disconnect the front panel sensor assembly connector.
  16. Remove the display assembly.
  17. Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray. Press to eject the tray.
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  18. Remove the SIM card tray from the iPhone. The SIM card will fall out of the tray easily.
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM card tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM card tray to protect your iPhone's internal components.
  19. Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket. Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  20. Remove the rear-facing camera bracket.
    • Remove the rear-facing camera bracket.
  21. Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up. Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  22. Remove the two screws securing the upper cable bracket:
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  23. Remove the upper cable bracket.
    • Remove the upper cable bracket.
  24. Use the flat end of a spudger to pry the upper cable connector up from its socket. Use the flat end of a spudger to pry the upper cable connector up from its socket.
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  25. Remove the three Phillips 1.3 mm screws securing the top left antenna component.
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  26. Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  27. Remove the antenna component.
    • Remove the antenna component.
  28. Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  29. Remove the grounding clip.
    • Remove the grounding clip.
  30. Remove the three screws securing the motherboard:
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  31. Use tweezers to gently bend the logic board grounding bracket out of the way. Use tweezers to gently bend the logic board grounding bracket out of the way.
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  32. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  33. Use the point of a spudger to pry up and disconnect the Wi-Fi diversity antenna cable. Use the point of a spudger to pry up and disconnect the Wi-Fi diversity antenna cable.
    • Use the point of a spudger to pry up and disconnect the Wi-Fi diversity antenna cable.
  34. Use the point of a spudger to pry up and disconnect the Lightning cable connector. Use the point of a spudger to pry up and disconnect the Lightning cable connector.
    • Use the point of a spudger to pry up and disconnect the Lightning cable connector.
  35. Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
    • Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
  36. Use the flat end of a spudger to gently lift the battery connector end of the logic board up. Be careful not to pull against any cables. If you feel resistance, check that all cables, connectors, and components are clear of the board.
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Be careful not to pull against any cables. If you feel resistance, check that all cables, connectors, and components are clear of the board.
  37. Grasping it by the edges, lift the logic board near the battery connector and remove it. Be careful not to snag the logic board on any cables. Be careful not to snag the logic board on any cables.
    • Grasping it by the edges, lift the logic board near the battery connector and remove it.
    • Be careful not to snag the logic board on any cables.
Conclusão
8 outras pessoas concluíram este guia.
Adam O'Camb
Membro desde: 11/04/2015
150.066 Reputação
418 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
139 Membros
15.650 Guias de autoria
2 comentários
Where can you buy a logic board
Charles Plechner - Responder
perfect, thanks!
wii8 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 25
Últimos 7 dias: 143
Últimos 30 dias: 630
Duração total: 6,858
