Ir para o conteúdo principal
iPhone Battery Adhesive Strips Replacement
O que você precisa
  1. iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: passo 1, imagem 1 %32 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: passo 1, imagem 2 %32 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: passo 1, imagem 3 %32
    • If your new battery came with adhesive strips already installed, skip to Step 8.
    • Otherwise, peel off the large blue plastic liner from your new set of adhesive strips, and discard it.
    • Once the adhesive is exposed, be careful not to touch it.
  2. iPhone Battery Adhesive Strips Replacement: passo 2, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 2, imagem 2 %32
    • Once the adhesive sticks to the battery, you can't peel it off or reposition it—if you make a mistake, you'll have to start over with fresh adhesive strips.
    • Double-check the orientation of the adhesive strips, and then stick them to the back side of your new battery.
    • Make sure the two shorter strips are nearest the battery cable connector.
    • Center the strips so that the two pairs of black tabs protrude evenly from each side of the battery.
  3. iPhone Battery Adhesive Strips Replacement: passo 3, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 3, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 3, imagem 3 %32
    • Use your fingers or a cloth to press the strips firmly into place on the battery.
  4. iPhone Battery Adhesive Strips Replacement: passo 4, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 4, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 4, imagem 3 %32
    • Flip the battery over, then peel away and discard the two blue plastic liners covering the ends of the adhesive strips.
  5. iPhone Battery Adhesive Strips Replacement: passo 5, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 5, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 5, imagem 3 %32
    • Grab the pink plastic liner at the bottom edge of the battery, and gently pull it taut.
    • Fold the liner over onto the battery and press down.
    • Let go of the liner, and the two black ends of the adhesive strips should remain stuck to the bottom edge of the battery.
  6. iPhone Battery Adhesive Strips Replacement: passo 6, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 6, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 6, imagem 3 %32
    • Repeat the previous step to adhere the ends of the two remaining strips at the top edge of the battery.
  7. iPhone Battery Adhesive Strips Replacement: passo 7, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 7, imagem 2 %32
    • Peel away and discard the small orange release liner covering the ends of the adhesive strips at the top of the battery.
  8. iPhone Battery Adhesive Strips Replacement: passo 8, imagem 1 %32
    • With the large pink release liner still in place, set the battery into your iPhone.
  9. iPhone Battery Adhesive Strips Replacement: passo 9, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 9, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 9, imagem 3 %32
    • Line up the battery connector and press it into place.
  10. iPhone Battery Adhesive Strips Replacement: passo 10, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 10, imagem 2 %32
    • Lifting from the outside edge, tilt the battery onto its side so you can access the final release liner.
    • Leave the battery connected to the logic board to help keep it positioned correctly.
  11. iPhone Battery Adhesive Strips Replacement: passo 11, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 11, imagem 2 %32 iPhone Battery Adhesive Strips Replacement: passo 11, imagem 3 %32
    • Peel away the final, large, pink release liner and discard it.
  12. iPhone Battery Adhesive Strips Replacement: passo 12, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 12, imagem 2 %32
    • Carefully position the battery and set it into the iPhone.
  13. iPhone Battery Adhesive Strips Replacement: passo 13, imagem 1 %32 iPhone Battery Adhesive Strips Replacement: passo 13, imagem 2 %32
    • Press the top and bottom areas of the battery firmly into place, allowing the adhesive strips to stick to the rear case.
  14. iPhone Battery Adhesive Strips Replacement: passo 14, imagem 1 %32
    • Be sure to disconnect the battery again before reassembling your iPhone.
    • Working on your phone with the battery connected can destroy sensitive components.
Jeff Suovanen
Membro desde: 08/06/13
410.254 Reputação
259 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
141 Membros
17.757 Guias de autoria
Um comentário
Can I make my own adhesive strips from 3M double-sided tape?
Joel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 28
Últimos 7 dias: 204
Últimos 30 dias: 973
Duração total: 28,920
