Ir para o conteúdo principal
iPhone 8 Pentalobe Screws Replacement
O que você precisa
  1. iPhone 8 Pentalobe Screws Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusão
14 outras pessoas executaram este guia.
Adam O'Camb
Membro desde: 04/11/15
196.299 Reputação
Autoria de 416 guias
2 comentários
This guide is used by many other guides as first step! Don´t laugh about it.
VauWeh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 39
Últimos 30 dias: 183
Duração total: 13,634
