Ir para o conteúdo principal
iPhone 8 Back Glass Replacement
Vídeo de Apresentação
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: passo 1, imagem 1 %32
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
    unless you are planning to replace multiple Back Glasses, purchasing a tool like this is not an interesting solution. The entire housing can be picked up for about 30$ with usb elements present ... although you will have a 4 to 5 hour job putting everything back together.
    Bill McNamara - Responder
  2. iPhone 8 Back Glass Replacement: passo 2, imagem 1 %32 iPhone 8 Back Glass Replacement: passo 2, imagem 2 %32
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: passo 3, imagem 1 %32
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Linha de Chegada
13 outras pessoas executaram este guia.
Phryne
Membro desde: 11/17/19
20.936 Reputação
Autoria de 18 guias
Um comentário
Where does it show the replacement I only see the removal?
ManDeen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 83
Últimos 30 dias: 307
Duração total: 55,465
