Ir para o conteúdo principal
iPhone 8 Back Glass Replacement
Vídeo de Apresentação
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: passo 1, imagem 1 %32
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. iPhone 8 Back Glass Replacement: passo 2, imagem 1 %32 iPhone 8 Back Glass Replacement: passo 2, imagem 2 %32
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: passo 3, imagem 1 %32
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Linha de Chegada
14 outras pessoas executaram este guia.
Phryne
Membro desde: 11/17/19
21.441 Reputação
Autoria de 18 guias
1Comentário do guia
Where does it show the replacement I only see the removal?
ManDeen - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 52
Últimos 30 dias: 230
Ao todo: 58,605
