Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Use this guide to remove or replace the volume button covers in your iPhone 7. This guide is for the physical buttons, and not the electronic switches beneath.
If you need to replace the volume control cable, follow this guide.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. Attach a suction cup to the lower half of the display assembly, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. Pull up on the suction cup to create a small gap between the display assembly and the rear case. Insert the flat end of a spudger into the gap. The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. Slide the spudger to the left along the lower edge of the iPhone. Twist the spudger to widen the gap between the display and rear case. Twist the spudger to widen the gap between the display and rear case.
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display. Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. Insert the flat edge of a spudger into the bottom right corner of the device. Twist the spudger to widen the gap between the display assembly and the rear case. Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. Pull up on the suction cup to lift up the display and open the iPhone. Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. Pull up on the small nub on the suction cup to remove it from the front panel.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place. Be careful not to damage the plastic clips on the top edge of the phone.
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
    • Three 1.2 mm screws
    • One 2.4 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  12. Remove the lower connector bracket.
    • Remove the lower connector bracket.
  13. Use the point of a spudger to lift the battery connector out of its socket on the logic board. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector. Remove the bracket. Remove the bracket.
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  16. Disconnect the front panel sensor assembly connector from its socket on the logic board. This press connector should also be reconnected one end at a time to minimize the risk of bending.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. Remove the display assembly.
  18. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray. Press to eject the tray. This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  19. Use the flat end of a spudger to disconnect the rear-facing camera connector. Use the flat end of a spudger to disconnect the rear-facing camera connector.
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  20. Remove the following Phillips screws securing the rear camera bracket to the rear case: One 1.3 mm screw
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  21. Remove the bracket.
  22. Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module. Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  23. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Comprar agora
    Comprar agora
  24. Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  25. Remove the upper cable bracket. Remove the upper cable bracket.
    • Remove the upper cable bracket.
  26. Use the flat end of a spudger to disconnect the upper cable connector. Use the flat end of a spudger to disconnect the upper cable connector.
    • Use the flat end of a spudger to disconnect the upper cable connector.
  27. Remove the Phillips screws securing the Wi-Fi antenna: Three 1.2 mm screws
    • Remove the Phillips screws securing the Wi-Fi antenna:
    • One 1.7 mm screw
  28. Remove the top left antenna. Remove the top left antenna.
    • Remove the top left antenna.
  29. Remove the following Phillips screws:
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  30. Remove the bracket. Remove the bracket.
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  31. Use tweezers to gently bend the logic board grounding bracket out of the way. Use tweezers to gently bend the logic board grounding bracket out of the way.
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  32. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board. Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  33. Use tweezers to gently derout the antenna cables from the metal bracket on the logic board. Use tweezers to gently derout the antenna cables from the metal bracket on the logic board. Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
    • Use tweezers to gently derout the antenna cables from the metal bracket on the logic board.
  34. Use the point of a spudger to disconnect the lower cable connector. Use the point of a spudger to disconnect the lower cable connector.
    • Use the point of a spudger to disconnect the lower cable connector.
  35. Remove the following screws:
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using an [produto vinculado ausente ou desativado: IF145-343-1] and driver handle.
  36. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  37. Use the flat end of a spudger to gently lift the battery connector end of the logic board up. Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
  38. Lift the battery connector end of the logic board and pull it up and out of the rear case. Be careful not to snag the logic board on any cables. Be careful not to snag the logic board on any cables.
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
  39. Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery. Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
    • Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
  40. Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery. Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
    • Use a pair of tweezers with blunt tips to peel back the other adhesive strip on the lower edge of the battery.
  41. Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone. Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
  42. Repeat the previous step for the second strip. Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case. If you removed both adhesive strips successfully, skip the next step.
    • Repeat the previous step for the second strip.
    • Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
    • If you removed both adhesive strips successfully, skip the next step.
    • Otherwise, if either of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
  43. If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case. Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or  hair dryer.
    • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    • Avoid bending the battery. Damage to the battery may release dangerous chemicals, and could start a fire.
    • Do not pry under the top third of the battery, you may damage the volume button ribbon cable.
  44. Remove the battery from the rear case.
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
  45. Remove the following Phillips screws: Two 1.9 mm screws securing the power button.
    • Two 1.9 mm screws securing the power button.
    • Three 2.3 mm screws securing the volume buttons.
  46. Remove the following 1.3 mm Phillips screws: One screw beside the rear-facing camera
    • Remove the following 1.3 mm Phillips screws:
    • One screw beside the rear-facing camera
    • One screw on the rear case
  47. From the outside of the phone, push the hold switch into the rear case with the point of a spudger. This action  will free the hold switch and gasket from the rear case.
    • From the outside of the phone, push the hold switch into the rear case with the point of a spudger.
    • This action will free the hold switch and gasket from the rear case.
  48. Use a pair of tweezers to remove the rear-facing camera. Use a pair of tweezers to remove the rear-facing camera.
    • Use a pair of tweezers to remove the rear-facing camera.
  49. Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case. Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
    • Moving from power button side of the phone, use an opening pick to separate the adhesive holding the antenna flex cable to the rear case.
  50. Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive. Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
    • Slide the point of an opening pick underneath the antenna flex cable towards the top of the phone, separating the remaining adhesive.
  51. Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case. Remove the antenna flex cable.
    • Use tweezers to move the antenna flex cable away from the edge of the phone, freeing the screw bracket from the rear case.
    • Remove the antenna flex cable.
  52. Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
    • Remove the 2.3 mm standoff screw securing the flash bracket to the rear case.
  53. Remove the flash bracket. Remove the flash bracket.
    • Remove the flash bracket.
  54. Use the point of a spudger to gently unseat the flash module. Use the point of a spudger to gently unseat the flash module.
    • Use the point of a spudger to gently unseat the flash module.
  55. Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case. Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
    • Use the blade of a Halberd spudger to separate the adhesive holding the microphone to the rear case.
  56. Gently fold the power button module from the edge of the rear case. Gently fold the power button module from the edge of the rear case.
    • Gently fold the power button module from the edge of the rear case.
  57. Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case. Continue to separate the adhesive by moving the blade towards the top of the phone. Continue to separate the adhesive by moving the blade towards the top of the phone.
    • Slide the blade of a halberd spudger under the power button end of the button cable to separate it from the adhesive on the rear case.
    • Continue to separate the adhesive by moving the blade towards the top of the phone.
  58. Continue to move the blade of the halberd spudger underneath the power and volume control cable. Move slowly to make sure that the cable is not damaged during removal. Move slowly to make sure that the cable is not damaged during removal.
    • Continue to move the blade of the halberd spudger underneath the power and volume control cable.
    • Move slowly to make sure that the cable is not damaged during removal.
  59. Slide the halberd spudger under the volume control portion of the button cable. Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive. Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
    • Slide the halberd spudger under the volume control portion of the button cable.
    • Gently slide the blade underneath the cable towards the bottom of the phone, separating the remaining adhesive.
  60. Remove the power and volume control cable.
    • Remove the power and volume control cable.
  61. Pull the volume button clip towards the bottom of the phone to free it from the bracket. Pull the volume button clip towards the bottom of the phone to free it from the bracket.
    • Pull the volume button clip towards the bottom of the phone to free it from the bracket.
  62. Pull the clip towards the top of the phone to remove it. Pull the clip towards the top of the phone to remove it.
    • Pull the clip towards the top of the phone to remove it.
  63. Pull the volume button clip towards the bottom of the phone to free it from the bracket. Pull the clip towards the top of the phone to remove it. Pull the clip towards the top of the phone to remove it.
  64. Slide the flat end of a spudger underneath the bottom edge of the volume button bracket. Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
    • Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
    • Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
    • Rotate the spudger to pop the bracket off of the peg on the volume button.
  65. Pull the bracket from the rear case. Pull the bracket from the rear case.
    • Pull the bracket from the rear case.
  66. Repeat the procedure to remove the second volume button bracket. Repeat the procedure to remove the second volume button bracket. Repeat the procedure to remove the second volume button bracket.
    • Repeat the procedure to remove the second volume button bracket.
  67. Use the pointed end of a spudger to push each of the volume button covers out of the rear case. Remove the volume button covers. Remove the volume button covers.
    • Use the pointed end of a spudger to push each of the volume button covers out of the rear case.
    • Remove the volume button covers.
Conclusão
24 outras pessoas concluíram este guia.
Scott Havard
Membro desde: 27/06/2016
43.023 Reputação
33 Guias de autoria
Removing the battery is excluded from this repair.
Josh M - Responder
R u able to fix water damage
alex - Responder
Hi r u able to fix water damage for iPhone 7
alex - Responder
Hi Alex, the repairability of water damage varies hugely depending on your unique circumstances, but this guide is a good place to start. If the damage is extensive you may want to take your phone to a local repair professional.
Adam O'Camb -
Bonjour je voudrais savoir si vous avais la même explication mais pour iPhone 7+ s’il vous plaît ??
Lydia David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 39
Últimos 7 dias: 219
Últimos 30 dias: 925
Duração total: 40,164
