Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Prereq only for battery removal when replacing the rear case.
O que você precisa
Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
