Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to remove or replace the power button in your iPhone 7. This guide is just for the physical button, and not the electronic switches beneath.
If you need to replace the volume and power control cable, follow this guide.
O que você precisa
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Ferramenta utilizada nesse passo:Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the iPhone.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
Remove the following Phillips screws:
Two 1.9 mm screws securing the power button.
Three 2.3 mm screws securing the volume buttons.
Pull the clip towards the bottom of the phone and lift up to free it from the bracket.
21 outras pessoas executaram este guia.
3 comentários
Alright so quick question…….
the clip shown in step 57 the one that resembles a staple,is this necessary?
Im doing a housing swap for myself and I cannot get these back on going on an hour now my hands are huge so im wondering if everything will be okay if I don’t replace these.(normally if it were another person’s device I would never take a shortcut,Never have and Never will in fact I despise this,but it’s my phone so it’s cool).
thanks
I can't see a response. Are the clips necessary?
It is probably to keep it in place, so I think it’s not necessary but recommended
