Ir para o conteúdo principal
iPhone 7 Plus Pentalobe Screws Replacement
O que você precisa
  1. iPhone 7 Plus Pentalobe Screws Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Pergunte ao FixBot
    Comentar
Conclusão
34 outras pessoas executaram este guia.
Evan Noronha
Membro desde: 02/05/15
229.532 Reputação
Autoria de 168 guias
5Comentários do guia
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - Responder Compartilhar
Hey Cooper,
There is no seal on the screw. The head of the screw simply pushes against the lip of the screw well, without using any sort of pneumatic seal, o-ring etc.
As Talon says, it is part of the casing.
Harry Rowse - Responder Compartilhar
I not recall seeing one. If there is one I would expect it to be part of the casing.
Talon - Responder Compartilhar
as the costumer said, there is a sealant but not noticeable
Mark Perick Quemado - Responder Compartilhar
how do i fix the charging port if the phone has been off for a while, 5 months to be exact and it refuses to charge
MuShï SheNï - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 117
Ao todo: 22,568
