Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
iPhone 7 Plus Home/Touch ID Sensor Replacement
O que você precisa
  1. iPhone 7 Plus Home/Touch ID Sensor Replacement, Pentalobe Screws: passo 1, imagem 1 %32
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Home/Touch ID Sensor Replacement, Opening Procedure: passo 2, imagem 1 %32
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 3, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 3, imagem 2 %32
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 4, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 4, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 4, imagem 3 %32
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 5, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 5, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 5, imagem 3 %32
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 6, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 6, imagem 2 %32
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 7, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 7, imagem 2 %32
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 8, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 8, imagem 2 %32
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 9, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 9, imagem 2 %32
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 10, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 10, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 10, imagem 3 %32
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 7 Plus Home/Touch ID Sensor Replacement, Battery Disconnection: passo 11, imagem 1 %32
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  12. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 12, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 12, imagem 2 %32
    • Remove the lower display cable bracket.
  13. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 13, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 13, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 13, imagem 3 %32
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. iPhone 7 Plus Home/Touch ID Sensor Replacement, Display Assembly: passo 14, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement, Display Assembly: passo 14, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement, Display Assembly: passo 14, imagem 3 %32
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 15, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 15, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 15, imagem 3 %32
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  16. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 16, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 16, imagem 2 %32
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 17, imagem 1 %32
  18. iPhone 7 Plus Home/Touch ID Sensor Replacement, Home/Touch ID Sensor: passo 18, imagem 1 %32
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  19. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 19, imagem 1 %32
    • Remove the bracket that secures the home/Touch ID sensor.
  20. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 20, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 20, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 20, imagem 3 %32
  21. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 21, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 21, imagem 2 %32
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
  22. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 22, imagem 1 %32
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
  23. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 23, imagem 1 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 23, imagem 2 %32 iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 23, imagem 3 %32
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  24. iPhone 7 Plus Home/Touch ID Sensor Replacement: passo 24, imagem 1 %32
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
99 outras pessoas executaram este guia.
Paige Reisman
Membro desde: 04/07/14
23.586 Reputação
Autoria de 15 guias
15 comentários
Correct, and that is also stated in the introduction. This guide is primarily for folks who need to transfer the home button onto a new/replacement display. So Jeff if I'm transferring button to a new display will I retain Touch ID functionality? Or would it be lost? My screen is cracked and I want to replace it. Thanks.
Victor Rodriguez - Responder
Yes, if you carefully move your original home button to your new display, it should be good as new, Touch ID and all.
Jeff Suovanen -
Can the home button not be removed through the back? Does it only come through the front?
Talon - Responder
You can replace the home button but your touch ID wont work anymore. Apple has it coded with your logic board. once you remove it yes, the home button will work well but you can't use the touch ID.
Rachelle - Responder
Hello,
The home button was cracked with keys in my pocket when it cracked the home button is started to heat when screen is turned off , when i use with display turned on the home button we not heat, Am wondering what could be wrong,
Any suggestion is appreciated
Does home button will work? after replacing with after-market home button, i just want know any one tried it?
i know touch id will not work.
Recently i have replaced the home button with after market, the phone will not boot up, just flashing with apple logo.
after replacing original it worked for me.
kishore.k kishore.k - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 177
Últimos 30 dias: 965
Duração total: 125,364
